Forum: EFI Tech
05-13-2023, 12:20 PM
There is a company (I forget the name) that the...
There is a company (I forget the name) that the LS crowd favors, that will make them to your dimension. A Google search will probably turn them up. If not I can find it on LS TECH, if you want.
ETA:...
Forum: EFI Tech
05-11-2023, 07:52 AM
Forum: Pontiac - Race
05-08-2023, 10:56 PM
Forum: EFI Tech
04-23-2023, 01:21 AM
If I'm understanding correctly, it sounds like...
If I'm understanding correctly, it sounds like you wanna be able to run different afr in different areas of engine operation. And yes the Holley and others like it can easily do that. What can...
Forum: Pontiac - Street
04-18-2023, 11:59 AM
04-16-2023, 10:09 PM
04-15-2023, 01:15 PM
04-15-2023, 12:40 PM
04-02-2023, 01:02 AM
So I changed the low beams out to the parts...
So I changed the low beams out to the parts linked by FJ. Operation is good, puts out good, clean white light. I'm not sure they're sealed well enough for a daily driver, but mine almost never sees...
03-26-2023, 12:06 PM
Forum: EFI Tech
03-24-2023, 07:45 PM
03-13-2023, 02:55 PM
03-13-2023, 01:45 PM
When using this as an anti roll bar for drag...
When using this as an anti roll bar for drag racing, the way to set those up is to:
Leave passenger side loose/unhooked. Put driver/drivers weight equivalent in the seat. Bolt up the passenger side...
02-14-2023, 07:25 AM
I'd find the rated amp draw of those items (or...
I'd find the rated amp draw of those items (or check them yourself with an amp clamp). Then do the math. The big pulley will likely diminish the alternators output, especially at low speeds. Easier...
Forum: EFI Tech
01-24-2023, 04:25 PM
Forum: EFI Tech
01-04-2023, 10:31 PM
Forum: EFI Tech
01-04-2023, 09:03 PM
Forum: EFI Tech
01-04-2023, 09:02 AM
Forum: EFI Tech
11-30-2022, 11:25 AM
10-16-2022, 04:49 PM
10-13-2022, 05:19 PM
10-08-2022, 04:50 PM
Absolutely. Take your time, you'll get it....
Absolutely. Take your time, you'll get it. Another thing, if you have jet extensions, or vent "whistles" added, extra caution is required. Sometimes it's helpful to fit the bowl to the metering...
10-07-2022, 02:11 AM
Forum: THE LOBBY
09-28-2022, 11:55 AM
Forum: EFI Tech
09-08-2022, 12:08 PM
EFI tuning guide
https://www.diyautotune.com/support/the_diy_efi_tuners_guide/?utm_source=newsletter090722_2&utm_medium=email&utm_campaign=EFI_Tuners_Guide_campaign&utm_id=EFI_Tuners_Guide_ID&mc_cid=14a06d7bd7&mc_eid=...
