Old 01-29-2024, 07:17 PM
grd777 grd777 is offline
Default is this connector for my reverse lights
i have a 1972 formula with a 4 spd tranny .I am trying to get my reverse light's to work ,would this be the correct connector
ID:	627495   Click image for larger version
Old 01-29-2024, 08:51 PM
I think that's the downshift connector? (which you don't use)
Old 01-29-2024, 08:54 PM
Look for a pink with black stripe and a lt. green connector.
back-up light not working?
Old 01-29-2024, 09:29 PM
yes not working. there is a post i started in the "parts wanted" discussing this topic
Old 01-29-2024, 10:36 PM
You might try and find the directional signal flasher. The wire connects to that wire I believe. (pink with black stripe) Maybe the previous owner cut it off if they went to the manual tranny?
Might look for the wires without a connector on them?
Old 01-29-2024, 10:52 PM
ok will take a look thanks for your input
Old 01-29-2024, 11:01 PM
bhill86's Avatar
bhill86 bhill86 is offline
Didn’t believe me in your other post? Lol
ID:	627509   Click image for larger version
1977 Trans Am 400/4speed (swap)
Brian
Old 01-29-2024, 11:46 PM
no just thought my car was altered
Old 01-30-2024, 12:39 PM
necdb3's Avatar
necdb3 necdb3 is offline
Because your car is a 4spd car, it is not a downshift switch, however, that same switch is used in 72 only to operate the shaker flapper door. If you connect the terminals together, your shaker door single wire should have 12v. That should attach to the gas pedal switch. Do you have a switch above your gas pedal? If not, you need to get one.
Dave
Old 01-30-2024, 12:43 PM
found the wire .next question ,does it matter how i install the wire to the switch .ie "green on the left"
Dave
my car is a formula
Old 01-30-2024, 12:48 PM
necdb3's Avatar
my car is a formula
Forgot that part, sorry. That is an unused connector in your model.
Old 01-30-2024, 01:08 PM
following...same issue
Old 01-30-2024, 03:18 PM
Shouldn't matter. the switch just completes the circuit.
Old 01-30-2024, 03:30 PM
ok thank you for your reply .lets give it a try
Old 01-30-2024, 03:54 PM
just plugged it in ,turned key on .no lights .does the engine need to be running .does that switch connect to something in the column. not sure what the p.o did
sorry for all these questions got a few days off and got nothing to do lol
Old 01-30-2024, 04:07 PM
Engine does not need to be running.
Probably the collar on the steering column is in the wrong position if the column rods are not on (connections on the tranny and column).
Needs to be in Reverse.
Check for 12 volts on one of the wires. (to ground)
Old 01-30-2024, 04:10 PM
Thumbs up
[QUOTE=johnta1;6482209]Engine does not need to be running.
will do
Old 01-30-2024, 10:05 PM
Formulabruce's Avatar
Since your car " Was" an automatic. That connector " might" have been plugged into a switch on the gas pedal bracket. You don't have the bracket, or switch, so just tuck up under dash.. your reverse connector is on the steering column, combined with neutral safety most likely
Old 01-31-2024, 08:55 AM
necdb3's Avatar
I never realized that this "was" an automatic car. So it still "should have the downshift switch, although it would be rendered inoperative since the auto trans was removed.
The reverse lights are not that circuit regardless. The reverse light circuit is a 2 pin connector with a pink/blk stripe and a green wire in the harness close to the take off to the downshift wires. The connector is located on top of the column very close to the firewall. The switch is visible looking in that location. If you simply use a jumper to connect those 2 wires together, the reverse lights should work with the key on.
Because the trans has been now switched to a 4spd. The proper reverse linkage must be acquired to spin the column to activate the switch.
The Following User Says Thank You to necdb3 For This Useful Post:
