Old 12-17-2018, 02:51 AM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
Thank you for sharing.
Better pics of Eagle stuff.
  #42
Old 12-17-2018, 02:53 AM
I don't think BES owns the approach but I appreciate your candor.
Originally Posted by Jeff Kinsler View Post
Yea I will not post it for the reason above but anyone can send their stuff there to get it machined. I think it actually was talked about on py somewhere and people were saying that's not a good way to do it.
  #43
Old 12-17-2018, 07:33 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Have been running my 4.5" stroke Scat crank for 12 years. Has seen I would guess at least 25,000 street miles and I get out to the strip a few times a year. Two different times I melted pistons back in 2006 and 2007. Been running at least a few 8 second passes each year since 2008. Short block has been together for the last 9 years, and it's a 1970 factory block, Eagle rods and Ross pistons. This is with a turbo.
  #44
Old 12-17-2018, 09:27 PM
Hooter's Avatar
Hooter Hooter is offline
How have your piston skirts looked and what length rod are you running? I had less than favorable results with a 4.75 crank and 6.7 rods in a street application with several thousand street miles.
67 Bonneville ragtop
  #45
Old 12-17-2018, 11:16 PM
v869tr6's Avatar
6.7" rods, short block hasn't been apart in 9 years.
  #46
Old 12-17-2018, 11:26 PM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
How many are running a 4.75 crank?
  #47
Old 12-18-2018, 12:38 AM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Default How about the MOLNAR 4.375" and 4.65" Stroke Crankshafts?
Anyone have any information on experience with the MOLNAR 4.375" and or 4.65" stroke 3" main journal crankshafts? For instance the cylinder wall wear?
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
  #48
Old 12-18-2018, 08:45 AM
PAUL K's Avatar
PAUL K PAUL K is offline
We've been building 4.375 stroke Pontiac engines for decades (not with Molnar crankshaft) and it makes great combination . No issues whatsoever. Not much experience with the 4.65 stroke.
Go fast, see Elvis!
  #49
Old 12-18-2018, 09:30 AM
Hooter's Avatar
I destroked my motor from a 4.75 Ohio to a Molnar 4.375. Both used same 6.7 rod. Less side loading on the pistons and able to get the pin out of the ring land(no ring supports). Crank was spot on. Only about 2,000 street miles and 10 passes, but so far so good.
  #50
Old 12-19-2018, 03:05 AM
lust4speed's Avatar
Originally Posted by Jack Ferris View Post
Great information Jeff.
I have a new SG 4.500 crank that came from AP but I’ve not heard a lot of feedback on them so I’m hesitant to use it. I do have a 4.250 SCAT crank so your post has been a plus.
My SG 4.500 crank is going on 3 years of racing with no problems. Mild 700 HP build shifting at 6,800 RPM. Had it checked and mag'd by the machine shop when first purchased and it was good to go.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
  #51
Old 12-19-2018, 12:40 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Thank you. My goal for this build is 860-880 HP. There are many opposing views on this particular brand of crankshaft, even on the "other brand" sites but most, if not all speak of the final machining process being the deal breaker and speak little about strength. I have to assume that no matter which company finishes them if they are overseas forgings they are very similar in overall strength. I'm sure some have been broken and I have spoken to a few in the bowtie camp that have broken an overseas forging, but that's where the story ends. No hows or why they failed. Mr. Kinsler's information is priceless as we all know the level of power he makes.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
  #52
Old 12-19-2018, 04:30 PM
Is that with or without any amount of filling in any of the water jacket area?
I read somewhere that such was required with the 4.5" stroke to avoid cylinder wall scuffing.
Would very much like to see some stories of the 4.375" builds.
  #53
Old 12-19-2018, 04:44 PM
PAUL K's Avatar
All the builds were performance deals so the the blocks were filled atleast to the water pump holes.
Go fast, see Elvis!
  #54
Old 12-19-2018, 04:48 PM
PAUL K's Avatar
I agree with all the above. Sometime research the 500557 block lol. We've used a handful of SGI cranks and never had issues with there cranks. A couple had oversized main journals but we skimmed them down to STD spec. For a while they were the only option for the 3.25 main 4.5 stroke crank.... they might still be??
Go fast, see Elvis!
  #55
Old 12-19-2018, 04:55 PM
So as to avoid the cylinder wall scuffing, is such a partial water jacket filling required for a 4.375" stroke. Or for a 4.25" or even 4.0"?
  #56
Old 12-19-2018, 06:12 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Stock block?
  #57
Old 12-19-2018, 06:21 PM
PAUL K's Avatar
Filling the block seems to help everything, from what we've seen in our experience. However the Boss Bird guys have had success without ever using block fill. I can't say it's a necessity but almost every serious effort stock block build we've done has been filled.
Go fast, see Elvis!
  #58
Old 12-19-2018, 06:22 PM
PAUL K's Avatar
Originally Posted by ponjohn View Post
Stock block?
Both but more stock block builds than aftermarket.
Go fast, see Elvis!
  #59
Old 12-19-2018, 07:59 PM
krisr's Avatar
krisr krisr is offline
Half fill? Just to help keep the mains a bit more rigid or are you talking more full fill and run alky?
  #60
Old 12-19-2018, 09:09 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
GTO JONES's
GTO Jones.......You are one of the few it appears.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
