Old 12-15-2018, 01:38 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Default 4.500 inch Scat Forged crank results
I know there have been some posts on here about how good or not how good the Scat Forged Cranks are and I have some positive results from them.
Last night I pulled the shortblock apart and the rod and main bearings (which are the same ones from last season) still look great. I am sure that running aluminum rods definitely help. I run some pretty high rpm also 8100 on the shift and trap 8500 and this crank has seen 8700 to 8800 rpms many many times. The BES oiling mod to the block and crank is one of the reasons this engine lives the way it does. Quality machine work is another reason why alot of people have had problems and that includes me. I would recommend using one of these cranks for anyone that is making up to 1500 horsepower. Hope this helps people that have been on the fence about using a 700.00 to 800.00 crank in an engine making decent horsepower. I purchased mine from Butler Performance and highly recommend them.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 12-15-2018, 01:48 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Great information Jeff.
I have a new SG 4.500 crank that came from AP but I’ve not heard a lot of feedback on them so I’m hesitant to use it. I do have a 4.250 SCAT crank so your post has been a plus.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-15-2018, 01:51 PM
I ran a 4.250 Scat that was turned down to 4.150 when I was running the 499 cubic inch deal and that was fine also
1.079 4.559 153.23.
3100 lbs
T2TTFMF!
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 12-15-2018, 02:13 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Nice info Jeff....... But you're on the 4.25 stroke max hit list now.
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 12-15-2018, 02:21 PM
mgarblik mgarblik is offline
Last night I pulled the shortblock apart and the rod and main bearings (which are the same ones from last season) still look great. I am sure that running aluminum rods definitely help. I run some pretty high rpm also 8100 on the shift and trap 8500 and this crank has seen 8700 to 8800 rpms many many times. The BES oiling mod to the block and crank is one of the reasons this engine lives the way it does. Qualify machine work is another reason why alot of people have had problems and that includes me. I would recommend using one of these cranks for anyone that is making up to 1500 horsepower. Hope this helps people that have been on the fence about using a 700.00 to 800.00 crank in an engine making decent horsepower. I purchased mine from Butler Performance and highly recommend them.
Thank you for that report and results from real on-track experience. This adds validity to my impressions after carefully looking those crankshafts over at PRI last year. Visually, to me the oiling circuits in the crankshaft are world's apart from the Eagle stuff and other off-shore offerings. I just hate the huge "winking eye" depressions Eagle uses to move oil from block to mains and then the rods. The Scat oiling looks similar to the way quality billet cranks carry oil. I will likely be buying a 3.25x4.25" Scat forging for my street car based on what I have seen and your experiences. Good info.
Old 12-15-2018, 02:27 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good info....thanks
Go fast, see Elvis!
Old 12-15-2018, 03:22 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
This must be fake news. I read on here that the ECM does not share information.
Old 12-15-2018, 04:04 PM
bad69bird's Avatar
bad69bird bad69bird is offline
LMAO^^^
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 12-15-2018, 04:26 PM
Any pics of the BES oiling mod to the block and crank?
How about pics of the crank oil holes on mains and rods?
Is the rear seal area smooth or cross-hatched?
Thanks.
Old 12-15-2018, 04:30 PM
bad69bird's Avatar
Thanks.
John,
IMO, I don't think that would be fair to BES to put that out there. They are in business to make money. It would be different if he came up with it himself and he wasn't going to market it. Jeffy might and that's his pejorative.
Old 12-15-2018, 05:19 PM
I think that should be prerogative?
That's fine on BES thing.
It's probably well known anyway to most builders.
Goes along with Quality machine work
Old 12-15-2018, 05:29 PM
slowbird's Avatar
slowbird slowbird is offline
He's trying to impress AQ
Old 12-15-2018, 05:49 PM
PAUL K's Avatar
AQ for Prez!
Go fast, see Elvis!
Old 12-15-2018, 06:18 PM
Here is a pic of what Eagle main oiling looks like. Essentially, a rough, giant trough, carved into the crankshaft journal. No scoop or lead into the direction of crank rotation. So large, the depression takes valuable support area away from the crankshaft. Many of the cheap Chinese shafts utilize this low cost approach of feeding oil to the bearings. If your making a few hundred HP with a V-8, probably works OK. NONE of the quality crankshaft manufacturers use this cut rate approach to oiling. Crower, Moldex, Winberg, Bryant, and now apparently Scat, choose to oil the mains properly with carefully designed scoops and directional oil flow. Not the best place to cut corners IMO.
Old 12-15-2018, 06:24 PM
Here are a couple of pics of what a correct main oil feed should look like.
ID:	500225   Click image for larger version
Old 12-15-2018, 06:35 PM
Better pics of Eagle stuff.
ID:	500227   Click image for larger version
Old 12-15-2018, 07:15 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Thanks for the info, Jeff. I've had very good results with my 4.00" Scat crank I bought from BOP. Saved a ton of money and time compared to waiting on a billet crank.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
Old 12-15-2018, 10:31 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Glad to hear it. Butler is almost thru with my 535 short block and that’s the crank we used with Oliver rods
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 12-15-2018, 10:47 PM
Mark G Mark G is offline
LOL..
Old 12-15-2018, 11:32 PM
Originally Posted by bad69bird View Post
John,
Yea I will not post it for the reason above but anyone can send their stuff there to get it machined. I think it actually was talked about on py somewhere and people were saying that's not a good way to do it.
1.079 4.559 153.23.
3100 lbs
T2TTFMF!
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
