TV bracket (200-4r & Q-jet)
I am almost ready to order the TV bracket and TV cable from CPT. It looks well thought out, well made, and it universal. While poking around in the JY the other day, I found this bracket on a late 70's Buick.
I think a throttle cable and kickdown cable attached to this bracket. The kickdown cable (or whatever is was) has the same end/attachment as the TV cable. Could it work as-is for my TV cable? As you can see in the pic, there is ~4" from the carb mounting studs to the TV cable mounting flange.
I never bought any unifix kits as I always copied the measurements and geometry from a factory equipped setup, be it carb or efi. Never had a problem.
___________________________________ "Objects in mirror are closer than they appear" |
I believe Car Craft or Hot Rod published a pic of the TV bracket from an early 80's Olds w/ a 307 and a QJet, back in the 90's. This was supposed to be a cheap, reliable way to hook up the TV system for junk yard prices.
Worth a look in the wrecking yards.
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
The MOST important thing to get right is the TV cable geometry. The jy bracket should work just fine but the tv cable needs a rotation pattern that differs from the throttle cable pattern. If you used that bracket AND the original throttle shaft originally designed for tv cable attachement, I see no reason why it wouldn't work as the factory intended. From what I've gathered, the tv attachment point should be approximately 10 degrees to the rear of the throttle shaft center (measured vertically).
I have the Bowtie Overdrives kit on my car and it works very well. But I have a spreadbore Holley, not a Qjet. I am having a Pontiac Qjet rebuilt with the throttle shaft, (and electric choke) from a late 80's GM. |
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y |
I bought about 2-3 of those I have on a shelf new from GM as they are for a 200 and a Qjet.
Do you have the GM part number for this bracket?
I had to make all the brackets and TV cable mount for my 67 Tempest Sprint when I did the 2004r swap in the 80s.
No one had any info or parts to do it at that time. Keep in mind that the Sprint Q jet mounts sideways and uses a bellcrank. TV cable adjustment and geometry is a make or break deal with this swap.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Yes you do have to make a bracket for it BUT IT IS THE CORRECT BREACKET to use and makes it easy to set up
oh yes its correct but it does not fit Pontiac .
Harry I'll dig them up I think they still have the sticker on them.
you mean b-man
FYI |
yess this gold iridited one is exact GM copy made by TCI
Sorry Harry yes B man. I thnk I know what tool box they are in and I'll look tonight.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune 13.43@103.4 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs Last edited by Skip Fix; 08-13-2012 at 12:32 PM. |
the TCI bracket is cheap and will do the same job ,
for ****&giggles i searched the bracket thru google and some in the Olds forums want as much $100+ thinking that GM one is discontinued.. when you get the number later well look in GM parts direct to see if it comes valid available or not then the people who are seeking the GM one will pay top dollar ...
GM # 22504927. I actually found something in my garage! Too many projects going and too many parts everywhere.
discontinued part.....
Thread Tools | |
Display Modes | |
