Old 08-09-2012, 03:40 PM
scld1354's Avatar
scld1354 scld1354 is offline
Default TV bracket (200-4r & Q-jet)
I am almost ready to order the TV bracket and TV cable from CPT. It looks well thought out, well made, and it universal. While poking around in the JY the other day, I found this bracket on a late 70's Buick.
I think a throttle cable and kickdown cable attached to this bracket. The kickdown cable (or whatever is was) has the same end/attachment as the TV cable. Could it work as-is for my TV cable? As you can see in the pic, there is ~4" from the carb mounting studs to the TV cable mounting flange.
Originally Posted by lust4speed View Post
Welcome to the broken nipple club - I'm a charter member.
Old 08-09-2012, 03:54 PM
Overkillphil's Avatar
Overkillphil Overkillphil is offline
I never bought any unifix kits as I always copied the measurements and geometry from a factory equipped setup, be it carb or efi. Never had a problem.
___________________________________
"Objects in mirror are closer than they appear"
Old 08-09-2012, 05:13 PM
JC455 JC455 is offline
I believe Car Craft or Hot Rod published a pic of the TV bracket from an early 80's Olds w/ a 307 and a QJet, back in the 90's. This was supposed to be a cheap, reliable way to hook up the TV system for junk yard prices.
Worth a look in the wrecking yards.
John
IG: @crawdaddycustoms
Old 08-10-2012, 11:48 PM
pont3 pont3 is offline
The MOST important thing to get right is the TV cable geometry. The jy bracket should work just fine but the tv cable needs a rotation pattern that differs from the throttle cable pattern. If you used that bracket AND the original throttle shaft originally designed for tv cable attachement, I see no reason why it wouldn't work as the factory intended. From what I've gathered, the tv attachment point should be approximately 10 degrees to the rear of the throttle shaft center (measured vertically).
I have the Bowtie Overdrives kit on my car and it works very well. But I have a spreadbore Holley, not a Qjet. I am having a Pontiac Qjet rebuilt with the throttle shaft, (and electric choke) from a late 80's GM.
Old 08-12-2012, 12:24 AM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
this is what you need
http://www.hkmotorsportsdynoshop.com/
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 08-12-2012, 12:28 PM
I bought about 2-3 of those I have on a shelf new from GM as they are for a 200 and a Qjet.
Old 08-12-2012, 12:34 PM
Do you have the GM part number for this bracket?
Old 08-12-2012, 06:00 PM
Cammer-6 Cammer-6 is offline
I had to make all the brackets and TV cable mount for my 67 Tempest Sprint when I did the 2004r swap in the 80s.
No one had any info or parts to do it at that time.
Keep in mind that the Sprint Q jet mounts sideways and uses a bellcrank.
TV cable adjustment and geometry is a make or break deal with this swap.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-12-2012, 06:02 PM
Ben Ben is offline
This is the bracket
http://www.ebay.com/itm/Throttle-Cab...e160bd&vxp=mtr
Old 08-12-2012, 07:53 PM
harry k's Avatar
Originally Posted by Ben View Post
the listing above is Chevrolet intake manifold use ONLY, will not fit to Pontiac , like the above one i listed that will bolt to carb rear bolts only ....
Old 08-12-2012, 09:11 PM
Ben Ben is offline
Yes you do have to make a bracket for it BUT IT IS THE CORRECT BREACKET to use and makes it easy to set up
Old 08-12-2012, 09:18 PM
harry k's Avatar
oh yes its correct but it does not fit Pontiac .
Old 08-12-2012, 10:15 PM
Harry I'll dig them up I think they still have the sticker on them.
Old 08-12-2012, 11:28 PM
harry k's Avatar
you mean b-man
Old 08-13-2012, 10:16 AM
Donovan Donovan is offline
Originally Posted by harry k View Post
This is the 307 bracket essentially.
FYI
Old 08-13-2012, 11:28 AM
harry k's Avatar
yess this gold iridited one is exact GM copy made by TCI
Old 08-13-2012, 12:25 PM
Sorry Harry yes B man. I thnk I know what tool box they are in and I'll look tonight.
Old 08-13-2012, 07:15 PM
harry k's Avatar
the TCI bracket is cheap and will do the same job ,
for ****&giggles i searched the bracket thru google and some in the Olds forums want as much $100+ thinking that GM one is discontinued..
when you get the number later well look in GM parts direct to see if it comes valid available or not then the people who are seeking the GM one will pay top dollar ...
Old 08-13-2012, 09:33 PM
GM # 22504927. I actually found something in my garage! Too many projects going and too many parts everywhere.
Old 08-13-2012, 09:41 PM
harry k's Avatar
discontinued part.....
