93-02 General Tech/Discussion 1993-2002 Firebird/Trans Am General Tech/Discussion |
05-08-2012, 07:01 PM
3rd Gen WS6-how to identify one?
Would there actually be WS6 markings on the body, or is it more of a vin/code reading exercise?
Thanks,
Russ
05-08-2012, 08:32 PM
They did not have emblems on 3rd gens for the ws6.The only way is to find the white RPO sticker and look at the codes,it would be there. Here is an example of what the label looks like.
05-08-2012, 10:56 PM
Thanks!
Russ
05-09-2012, 12:11 AM
In most of the 3rd gen cars I've had and parted, the rpo code sticker is glued on the underside of the council lid.
05-09-2012, 01:37 AM
Thanks.
turns out that the person I got some info from meant second gen. Oh well, never hurts to learn stuff.
Russ
05-09-2012, 07:36 AM
In that case, PHS.
And go racin' in the street.
05-12-2012, 11:51 PM
What its it...ALL 87-92 Formulas where WS6s. ALL GTAs were. Most TAs were (but not all.)
06-04-2012, 01:04 PM
My '87 has a Performance Suspension applique on the dash, but like almost everything else on the car, it's crooked. It's an LB9+MM5+J56+WS6 Formula.
The only time 4WDisc was standard was with LB9+MM5, regardless of model; B2L 5.7L regardless of model, and any 1LE vehicle. Other than that, it was available and recommended, bu not standard.
08-19-2012, 06:28 AM
I disagree
I disagree, my decoded VIN clearly says Formula built in St. Theresa, Canada with special suspension. It's a Trans Am without the exterior panels.
My deck/hatch area has a factory WS-6 suspension emblem.
'65 GTO Hardtop
389 .030 400ci Tri Power, .068 cam, HO manifolds, M-20 4 SPD, '70 12 Bolt 3:36 Chevrolet posi-traction, Montero Red, Parchment gut, VINTAGE AIR, PFDB, Bilsteins, F&R HD Sways, Hotchkis rear bags, Firestone Indy 500 shoes
"What's the point of owning a muscle car if you can't scare yourself stupid from time to time ?"
08-19-2012, 09:45 AM
dlarkins, this thread is about 3rd-gens, NOT 4th-gens Firebirds. The picture you posted is of a 4th-gen.
