Closed Thread
Old 12-16-2019, 09:17 PM
Originally Posted by LiL Jack View Post
That’s because you don’t make any power to hurt anything!
Lol..truth.. there are stock blocks taking more than george has...
  #42
Old 12-16-2019, 09:30 PM
How much HP does it take to break a block?
How much for the AP blocks that broke?
Danny Estep ??
Curt Geise ??
GTO on PY ??
TimeWarp ??
Others ??
  #43
Old 12-16-2019, 09:42 PM
GTOGEORGE's Avatar
My engine makes more hp then 90% of the Pontiac out there.....I’m happy!
GTO George
  #44
Old 12-16-2019, 10:24 PM
PAUL K's Avatar
PAUL K PAUL K is offline
GTO George
Being happy is what it's all about!
Go fast, see Elvis!
  #45
Old 12-16-2019, 10:30 PM
GTOGEORGE's Avatar
You know unless your name is Brittany Force there’s always someone quicker! LOL!
GTO George
  #46
Old 12-16-2019, 10:47 PM
Mark G Mark G is offline
Danny Estep ??
Curt Geise ??
GTO on PY ??
TimeWarp ??
Others ??
You forgot Goatracer I will think of a few more ….
  #47
Old 12-16-2019, 10:55 PM
PAUL K's Avatar
GTO George
Always
Go fast, see Elvis!
  #48
Old 12-16-2019, 11:18 PM
mgarblik mgarblik is offline
Danny Estep ??
Curt Geise ??
GTO on PY ??
TimeWarp ??
Others ??
Our on track experience:
3 Stock block Pontiac 455's 1971-1973 vintage
5 billet straight caps. 1.5-2 seasons for each block @ 1100-1300 HP All three blocks broke in the same place up through the #2 main bearing oil feed from the cam bore to the main housing bore.
Indian Adventure Iron: Unlimited runs @ 1300-1500 HP (hundreds of passes and bad tune-ups) No block issues
IAII Iron block: Probably close to 3000 HP Multiple years of running on 90% nitro. Some pretty bad tune-ups, melting pistons through the wrist pins, turning Crower billet crankshafts to liquid, entire car burned to the ground. No Block Failures
IA II solid aluminum block: 3 seasons at 3000 HP 5-6 runs at 3200-3400 HP. 40+ lbs. Boost, 90% nitro, 9000 RPM's. No crank support or harmonic balancer. No block failures. In fact the block will not require line honing this off season. Better tune-ups take massive load off the block. IA II blocks are tough in iron or aluminum
  #49
Old 12-16-2019, 11:51 PM
Go buy lotto ticket...
  #50
Old 12-17-2019, 12:58 AM
Stan Weiss's Avatar
Some of really comes down to tune up.
Marty Palbykin @ 2950 went 6.95 @ 195 MPH using a PMD iron block and heads.
Stan
Pontiac Pump Gas List
  #51
Old 12-17-2019, 01:10 AM
GTOGEORGE's Avatar
Stan
He used a factory block because he HAD to, I’m pretty sure a lot of time and money went into his block. No one likes to play Russian Roulette! LOL!
GTO George
  #52
Old 12-17-2019, 10:19 AM
GTO George
Sorry, I have to respond on this one.
Dick Duclow's IA-1 block was out there at the time.
Rodney Butler chose to run one of those blocks as a 440 cid engine and did for years.
Marty could have bought a Duclow Block if he wanted to.
He chose to use the 1967 400 Block that came from Bill Klausing and put splayed caps on the block. It lasted 3 years and also eventually cracked in the same location as the blocks mentioned by Mike Garblik.
So what was posted was not true and the truth needed to be told..
I will only post here if the post is a bold faced lie.
  #53
Old 12-17-2019, 10:26 AM
opeliac opeliac is offline
Didnt Marty run a filled block?
  #54
Old 12-17-2019, 11:16 AM
GTOGEORGE's Avatar
Anyone know what year the IA block came out? I bought one, I’m trying to remember what year it was that I got it........2004 or 5. Jeff had one in his shop but at that time they were almost impossible to find at that time.
GTO George
  #55
Old 12-17-2019, 11:37 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is online now
Larry Quinn broke his block also
Illinois Outlaw Gassers
6.27@107
9.97@131
  #56
Old 12-17-2019, 11:55 AM
Then we will be seeing a lot of you..
  #57
Post by Scott Misue in 1999
http://forums.maxperformanceinc.com/...12#post1712412
"Gach is not an easy man to impress. However, Marty's accomplishments with turbos has definitely caught his attention. Lou seems to be a bit miffed by the fact that Marty wasn't given, sold, or stolen, a block to test. I think Lou's ire may also stem from the fact that Marty isn't a vendor of this block and, as such, wouldn't conceal his combo, reults, or the components employed in its testing."
So Scott Misus way back in 1999 was complaining about Marty P not having access to an Indian Adventures block, not that he could not afford to buy one.
So the reply by George was BS.
  #58
Old 12-17-2019, 11:57 AM
At least on this one subject but I have posted to correct info and the timeline so I am out of here again.
  #59
Old 12-17-2019, 12:06 PM
GTOGEORGE's Avatar
WOW. I think someone is PMSing! LOL!
GTO George
  #60
Old 12-17-2019, 12:25 PM
GTOGEORGE's Avatar
Cool I opened the link and read all 3 pages......damn that was some good reading! Gacht was a jerk back then also! LOL! At least I now when the IA block came out ( I was kinda guessing). I was rethinking and maybe I got mine in 2004, darn now I have to go looking for my invoice from KRE!
GTO George
Closed Thread
