But with that being said, if you copy the drawings of the first aftermarket block that was copied from the OEM block who exactly are you copying? |
Just saying both blocks are "copies" of the Pontiac dimensions.... I wasn't referring to the underhanded stuff that went on in that whole deal |
Microsoft Corporation, 35 F. 3d 1435 (9th Cir. 1994), was a copyright infringement lawsuit in which Apple Computer, Inc. ... sought to prevent Microsoft and Hewlett-Packard from using visual graphical user interface (GUI) elements that were similar to those in Apple's Lisa and Macintosh operating systems. In the midst of the Apple v. Microsoft lawsuit, Xerox also sued Apple alleging that Mac's GUI was heavily based on Xerox's. ... Apple lost all claims in the Microsoft suit except for the ruling that the trash can icon and folder icons from Hewlett-Packard's NewWave windows application were infringing. What this means is if you have copied something from someone and someone copies it from you don't think you can sue them. Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
Pretty sure but it's been a while since I looked at real information on copyright and patents if you copy BUT change a small percentage then its deemed ok because there is a substantial amount of deviation from the original
And on a engine block that wouldn't be hard to accomplish
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
2009 I purchased a block from KRE at Norwalk when they discounted them for the show but I haven't used it still. I'm hoping it was the improved block. It doesn't have any markings around the distributor hole. Hoping
it will be a good block whenever or if I decide to us it. |
use it. lol
GTO George |
The only MR-1 blocks that had issues are the tri-cast ones... I can't speak for all of them, only mine..
That problem has been corrected... either block, ia2 or Mr-1 will work for the you... that's the short answer... I don't say that lightly... trust me, I cant stand kre for the way they handled my issues.... So a good review coming from me is painful yet honest... |
GTO George |
One thing you can count on George.... despite my personal prejudice, I will give an honest answer to a potential buyer...I still think you're a sawed off dildo...
Buy the way, why don't you but the D rotor screw? I will loan you a 14-71 if you will turn it up.. I think you're scared.....
I will loan you a blower with bag if you run it at 30% or more.... It's not one of those little street blowers u run...ita a retro case with 120° rotors... Most likely, it would blow you chit up.. |
Not a hollow offer George...I have loaned out many parts...
I loaned out a blower bag to Bobby Martindale for a George race.. google that...he WAS a good friend.. Last edited by Scott Roberts; 12-14-2019 at 10:42 PM. |
Mains were good. I bored and honed to size. Decks are good but I still decked them to get to zero with the rod/piston combo I was using. Same goes for both blocks.
http://www.youtube.com/watch?v=t9eWgLd0q-U |
The only aftermarket block failure( more than one) I seen is the IA2 block I never seen or heard of a MR1 block fail since KRE fixed their casting problems .JMO ..
A lot of part (any part) failures are in the build, lack of knowledge ior understanding is a big cause of it.
GTO George |
Not always ..
#38
I did not say always, there is a lot of ignorance out there when build a high hp engine.....if it was easy everyone would or could do it!
Anyone can build a time bomb and have it break and blame it on faulty parts. GTO George |
#39
The aftermarket block should be viewed as core blocks. Everything needs done to them but in the end you have something that can take what you throw at it. Thinking other wise is stupid.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#40
That’s because you don’t make any power to hurt anything!
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
Closed Thread |
