If it is "T" plumbed, when you corner it will exaggerate body roll.
I have no brand recommendations, just please buy American-made. |
American Made?
Thanks!! Dave
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
kyb's here, got them off summit/jegs for pretty darn cheap....very pleased.
1964 Catalina Convertible |
http://www.racecardynamics.com/class...hr/indexhr.htm Steve Duck RCD SUSPENSION 1900 Weld Blvd. El Cajon, CA 92020 Ph# 619/588-4723 Ext#109 Fax#619/328-9439 Email info@rcdclassics.com Hours 8am-5pm |
Using the KYB part number given above (KG5438). I used that to find what car those shocks would fit on Rock Auto. I got a list that I used to bounce off of the Gabriel site. I got the part number of 49310 for air shocks.
So I ordered the Gabriel Skyjacker 49310 and the 140656 dual plumbing kit. I will update you on the install. I has the rear of the car up to replace the e-brake cables, so nows as good a time as any,.
This always happens.....
Driver side 15 minutes.... Passenger side, the sleeve between the shock tower that the shock top rides on is rusted to the bolt. Either the penetrating oil I left on there overnight is going to allow the bolt to be popped out or I have to use the blue wrench to get it out. The Gabriel 49310 is an OK fit. It would be nice if it was a few inches taller, but I don't think I'll be Baja'ing the wagon anytime soon.
Had to plasma cut out the passenger side shock. Got the air shocks in and the dual line set-up. I filled them to 80lbs.
WHOA!!! 80 is too much with no one sitting in the back... Dropped the pressure to 45 ish.. Rides nice. I have not tested out the sitting on the tailgate thing yet. But we only had one warm weekend here and I was driving the other Yak.. Thanks for the input!!!! Dave
