Old 03-30-2024, 01:49 AM
dataway's Avatar
dataway dataway is offline
Default Open trailer with cover on car
Wondering if it's advisable to tow my GTO on an open trailer with the cover on. It has a soft inner surface. I'd go to extensive lengths to secure it as tightly to the car as possible, probably add a ton of grommets for bungees.
Just wondering if would survive for an 1100 mile trip, towed behind a pickup with a cap, without wearing through the paint (BC/CC). Paint is not outstanding so if it dulls some areas I'm not worried about it, I'll buff it out.
I have driven straight through several times, but this trip would be slower so might require an overnight stop ... just don't want the car visible while I'm asleep.
I guess I could cover it up when I stop for the night, and take it off for travel if necessary.
Old 03-30-2024, 02:09 AM
Don’t tow it with the cover on.
It will abrade the paint especially on any corners.
The Following 4 Users Say Thank You to b-man For This Useful Post:
Old 03-30-2024, 04:06 AM
dataway's Avatar
What about if I cover all the sharp corners with a couple of layers of tape?
I really want to draw as little attention as possible both in transit and while stopped.
Old 03-30-2024, 04:50 AM
242177P's Avatar
242177P 242177P is offline
Think about just how many flaps per minute a
cover will do at highway speeds. Just how slow
are you prepared to travel?
I'm hesitant to write this, but... if there are stake
pockets you could semi-enclose the trailer? You
would need four sheets of plywood just to create
4' sides. But most of the car would now be out of
plain view. No shortcuts here pls.
The Following 3 Users Say Thank You to 242177P For This Useful Post:
Old 03-30-2024, 06:50 AM
Jeff Hamlin's Avatar
You might look into the plastic crash wrap but otherwise,
I think you'll be sorry if you attempt to use a cover on an open towed car.
Old 03-30-2024, 08:03 AM
sdbob sdbob is offline
I wouldn't tow with cover as others have said the constant wind flapping corners. You may put some kind of faring (I have know experience with faring just thinking)on front of trailer. I'd make sure waxed good before trip. After trip clean your car.
The Following 2 Users Say Thank You to sdbob For This Useful Post:
Old 03-30-2024, 08:12 AM
rwfisher's Avatar
rwfisher rwfisher is offline
The cover is just going to cause issues and you’ll be worried about what is happening under the cover the whole trip.. It will obviously make people even more curious to what’s underneath and really do nothing to deter thieves if that is your worry. Clean it, wax it and tow it. Good chain Wrapped under it with a lock as well as a tracking device such as Apple Air Tag to help secure it (actually, 2 are better. 1 easy to find, one well hidden under car).
The Following 3 Users Say Thank You to rwfisher For This Useful Post:
Old 03-30-2024, 08:18 AM
Show it off.
Old 03-30-2024, 08:36 AM
Radman's Avatar
Radman Radman is offline
There are two very good reasons to not have a cover on the car while it is being towed. As others have said, it will damage your paint if not remove it completely on some of the corners. The second is no matter how well the cover is secured there is a chance of it coming off of your car and ending up on another car's windshield. Clean it wax it and show it off while you are traveling. Here is a picture of my Tempest on the trailer for a trip to Chicago. One thing I did add to my trailer was a critter/stone guard at the front.
Name:	Tempest on the trailer.jpg
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
The Following 4 Users Say Thank You to Radman For This Useful Post:
Old 03-30-2024, 11:31 AM
If you are worried about people seeing it.. rent an enclosed trailer. If you are worried about someone stealing it at a motel... Back the trailer into a pole or a wall.
1974 Formula 400 - Ram Air automatic
The Following 3 Users Say Thank You to 71GP76TA For This Useful Post:
Old 03-30-2024, 12:22 PM
Buy a few energy drinks and drive it straight through.
Make some sandwiches so your only stops will be for refueling.
Old 03-30-2024, 12:24 PM
Rustytinman55 Rustytinman55 is offline
Default Cover on opened Trailer
Be very careful about transporting on an open trailer with a car cover.
Flapping covers in the wind can ruin a beautiful paint job.
The Following 2 Users Say Thank You to Rustytinman55 For This Useful Post:
Old 03-30-2024, 12:38 PM
455HOGT37's Avatar
455HOGT37 455HOGT37 is offline
If theft is the fear, I think the cats on the tow vehicle or the Civic parked next to you are far more vulnerable than an old GTO.
The Following 2 Users Say Thank You to 455HOGT37 For This Useful Post:
Old 03-30-2024, 01:51 PM
BILL BOWMAN1's Avatar
Not even in an enclosed trailer.
The Following 2 Users Say Thank You to BILL BOWMAN1 For This Useful Post:
Old 03-31-2024, 04:20 AM
dataway's Avatar
Well, thanks folks, I guess it will be no cover.
The plan IS to drive straight through ... but if we have to stop I'll put the cover on while it's parked.
I'm flexible enough with dates that I can wait for a couple of day window of good weather.
Shucks, I guess I'll have to put but with all the "thumbs up"'s and compliments
Old 03-31-2024, 08:19 AM
triathlonx13's Avatar
No to hauling car with car cover on open trailer.
The Following 2 Users Say Thank You to triathlonx13 For This Useful Post:
Old 03-31-2024, 08:36 AM
...and nobody suggested to Drive the GTO. If ya had Overdrive, then it would be a great idea.
Old 03-31-2024, 10:16 AM
98 SNAKE EATER 98 SNAKE EATER is offline
Any loose fitting cover will cause damage at speed
If you're worried about rock chips, use either adhesive crash wrap or wrap tightly with luggage wrap
I do this for my bikes and motorcycles on long road trips
The Following 2 Users Say Thank You to 98 SNAKE EATER For This Useful Post:
Old 03-31-2024, 11:00 AM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
You mention putting the car cover on if you stop.
I would not do that. Don't put a car cover on over a dirty painted surface. Scratch the heck out of it.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
The Following 3 Users Say Thank You to hojs69 For This Useful Post:
Old 03-31-2024, 11:20 AM
Trulyvintage's Avatar
Trulyvintage Trulyvintage is offline
Thumbs up
A car cover can damage a paint
job even on an enclosed trailer.
There is no substitute for
enclosed vehicle transport.
Jim
The Following User Says Thank You to Trulyvintage For This Useful Post:
