Old 10-20-2023, 12:18 PM
chief2k chief2k is offline
Default Idle adjustment screw tool
What’s everyone using to adjust the driver’s side mixture screw? I’ve been using a 45 Deg turning tool on my ‘66 but it no longer fits in there since I installed the correct brake booster fitting on the front carb.
Old 10-20-2023, 01:39 PM
Kenth's Avatar
Kenth Kenth is offline
I use one like this. You can sneak it in straight from the front on the driver's side. None of the included pieces need to be used, as the end fits directly on the mixture screw.
Name:	Idle mixture adj. tool.JPG
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-20-2023, 02:22 PM
Perfect, thank you! Can you please tell me who makes it? Can't see it in the photo.
Old 10-20-2023, 02:34 PM
Found it on Amazon, thanks again!
Old 10-20-2023, 08:01 PM
Dick Boneske's Avatar
On the driver's side, it helps if you turn the power brake vacuum line up out of the way.
I use the same flexible tool,, and sometimes, a piece of 1/4" rubber vacuum hose about 6" long.
BONESTOCK GOATS
'99 Bonneville SE Sedan
The Following User Says Thank You to Dick Boneske For This Useful Post:
BONESTOCK GOATS
Old 10-20-2023, 10:47 PM
That sounds like a great idea. Never thought to use vacuum hose. Thanks
Old 10-21-2023, 12:35 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I've hated adjusting idle mixture on a Tri-Power since 1959. So my GMC requires no tool.
I drilled the screw heads and brazed speedometer cable pieces into them.
The Following 2 Users Say Thank You to Jack Gifford For This Useful Post:
Old 10-21-2023, 09:43 AM
mgarblik mgarblik is offline
I use the same flexible tool pictured. I used some red nail polish to paint a reference line on the tool handle. Makes it easier to keep track of adjustments and keep the idle mixture screws balanced.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
