#61
Looking at this thread and searching others, has anyone got first hand experience with running RA/HO manifolds in a 66 GTO, that are round port, from Ram Air Restorations with the 2.45" outlet? Just curious...
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
#62
Just received a set of manifolds. Transaction went smoothly. I am curious though. One of the bolt holes does not seem to have much meat around it. Is this normal? Looks like it could crack easily. All the other bolts have much thicker metal around them.
#63
looks like the bolt pattern is off a bit on all the tabs, i would try and get a better pair, but they probably would be fine with the studs installed
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
#64
I would right away send those back!!
That hole will tare out even with a stud in short order. It’s quite unmistakable that the whole bolt pattern for the exh pipe flange is misdrilled. The only way I would use that would be to install a long enough stud in that one hole such that it could be braised to the outer wall of the manifold a bit further up from the flange.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 09-12-2023 at 04:13 PM. |
#65
Here is what one of mine looked like before I sent it back.
1970 GTO (Granada Gold) - 400 / TH400 |
#66
How do they ship?
If that damage did not take place during shipping then it’s also clear why the other persons manifold was just sent out with it being drilled wrong, that being the owners don’t care about the quality of what they sell.
#67
IIRC...they were packed with bubble-wrap, but a little loose in the box.
Since there was no other damage noticeable on the other manifold and no pieces in the box, I had to assume it was pre-shipment (FedEx).
#68
If that was done in the box, the box would have been damaged.
Greg Reid Palmetto, Georgia |
The Following User Says Thank You to Greg Reid For This Useful Post: | ||
#69
Will you be calling RARE? I have to inspect mine and see if they are the same. Curious as to what Paul will say.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
#70
I thought all were off centered so the 3 flange would clear the frame better?
And grinding marks everywhere...
So long, farewell. |
#71
![]() Quote:
That's exactly what I was told. Seems odd but must work. There are a lot of these manifolds out there. |
#72
I've seen the holes like that in the past, I'm thinking if they were sent back for exchange the replacements would be the same. Like Ransom said I think they are that way on purpose for the 3 bolt flange setup, for more clearance. Technically I think one side is supposed to be a 2 bolt setup originally.
I'd put the studs in it and run it. Now the damage that vertigoat showed, yeah that could possibly cause a sealing issue and I'd likely send that back. Edit: Ha you must have been typing that when I posted. I figured that's the answer you'd get. |
#73
I ordered the bolt kit with mine and where the manifolds to head bolts are all hardware store type, grade 8. The flange bolts are ARP. I'd prefer to do studs for the flanges - has anyone found a good source for these? Wonder if these will work: https://shop.advanceautoparts.com/p/...b&gclsrc=3p.ds
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 09-13-2023 at 07:18 PM. |
#74
Would the 2 bolt drivers side manifold clear the 66 frame? My 72 has the 2 bolt manifold.
#75
![]() Quote:
I used a couple of these kits... https://shop.advanceautoparts.com/p/...03112/17190189
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
#76
I've never personally tried it on a 66 so can't say for sure.
The Following 2 Users Say Thank You to Formulajones For This Useful Post: | ||
#77
![]() Quote:
The Following User Says Thank You to Formulajones For This Useful Post: | ||
#78
Thanks all
#79
![]() Quote:
The Following User Says Thank You to b-man For This Useful Post: | ||
#80
Not much of a RAM AIR guy. I live in 64-65. I know they are 69. Any good??
Thanks Greg. "Bill"! |
