Old 12-20-2022, 09:38 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Default Oil pump 102
Anyone familiar?
ID:	603848   Click image for larger version
ID:	603849   Click image for larger version
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 12-20-2022, 11:53 PM
"Oh no you didn't." "You did?" "What did it do?" " ZERO !!" " Zero oil pressure!" " you suck !" On a serious note; does it work?
Old 12-21-2022, 12:53 AM
Dragncar Dragncar is offline
Has to be hard on oil pump intermediate shaft.
Old 12-21-2022, 01:08 AM
x2
Old 12-21-2022, 09:51 AM
x2. Tom V.
. Nearly twice as hard on the cam/dizzy gearset.
Old 12-21-2022, 10:23 AM
mgarblik mgarblik is online now
Somebody had an idea they wanted to try. It would be interesting to rig it up and measure, volume, pressure and drag in that contraption. Interesting piece of history. Kind of a "solution in search of a problem" If there is one thing in a traditional Pontiac engine that needs little attention to 700+ HP, it's the stock oil pump. IMO
Old 12-21-2022, 12:24 PM
charlie66's Avatar
id like to see the inside. Interesting ...
My Half AN Injun.....
Old 12-21-2022, 12:33 PM
25stevem's Avatar
25stevem 25stevem is offline
Somebody is or was bored and had the time to cut off or mill off the upper section of a pump to stack them I bet.
X 2 with the above post.
There seems to be a bottom plate right where it should be for the stock looking upper pump set up and the drive tang end looks to be stock also and if the pumps where stacked there wound seem to be no need for a middle plate like it has, only a gasket.
Care to take it apart for use and take +'post up more photos?
I do stuff for reasons.
Old 12-21-2022, 01:52 PM
J.C.you's Avatar
This would have to be a round and round setup or a two individual pans reservoirs. Or perhaps a boat?
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 12-21-2022, 02:21 PM
...if the Bottomplate was the sump pickup, to a single stage gearotor, then THAT could be an improvement.
Old 12-21-2022, 04:12 PM
johnta1 johnta1 is online now
My 2 cents:
I figured the gears are doubled (brazed together?), the bottom part is a continuation of the inside cavity. (basically double of the original).
The increase in volume would be good for racing and turns.
Also, would think the top hole (inlet) has a plug in it. (not being used)
Old 12-21-2022, 04:56 PM
dataway's Avatar
dataway dataway is offline
High flow for thin oil. Maybe someone looking to get that last bit of power running 5wt oil
If it was for picking up oil in a circle track car or similar .. wouldn't the uncovered pickup suck up a bunch of air?
Old 12-21-2022, 05:49 PM
J.C.you's Avatar
If noticed… the bottom (grafted pump) has the smaller pickup opening
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 12-21-2022, 07:17 PM
Looks like it was a "Do it Yourself" version of the Pontiac Titan Oil Pump some of the NSS Pontiac Guys ran years ago. (Before the "Straight Shot" oiling crankshafts from Moldex were offered). TSE-1100 pump
https://butlerperformance.com/i-2445...-tse-1100.html
Old 12-21-2022, 08:38 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Looks like an attempt to build a hi-volume pump for a Pontiac. The builder took the initiative to build an oil pump rather than sit on the Internet for twenty years and wait for Luhn to do it. If the current owner had as much initiative, he would've taken it apart and seen how it worked rather than post pictures on the Internet and accomplish little.
Who knows maybe the original builders name was Titan.
Go fast, see Elvis!
Old 12-21-2022, 09:07 PM
Scott Stoneburg's Avatar
Interesting, and kinda cool. The original owner trying to solve something he thought was an issue.
As far as uncovering one of the pick ups, I believe other brands have been using 2 picks up in circle track racing without issues with sucking air
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 12-21-2022, 09:09 PM
242177P's Avatar
242177P 242177P is offline
... builder took the initiative to build an oil pump rather than sit on the Internet for twenty years ...
I've thought about milling old pumps to create spacers for longer gears (1/4"? 1/2"? 3/4"?) but without a test rig it's just guesswork. Split the difference between two pumps you'd have an oval (peanut?) shaped inlet. I just wanna graft things together, math maek brane hurt.
Name:	buick plate.jpg
Old 12-21-2022, 09:15 PM
Luhn Performance and Titan have had their HP modded oil pumps out there for at least
10 years.
Old 12-21-2022, 11:51 PM
PAUL K's Avatar
That is nice and a good idea. Similar to the Buick high volume kits. Butler had a deal going using an extension that bolts to a factory style Pontiac pump and used longer gears. I don't know if it ever made it past the advertising stage.
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
Old 12-21-2022, 11:53 PM
PAUL K's Avatar
10 years.
Hi Tom, we started using the Titan pumps for our hi-end Pontiac builds around 2000.
Go fast, see Elvis!
