Old 06-23-2021, 09:06 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Default Speedmaster heads track results ?
I know there are several older threads on these affordable heads and I try to keep up on others posts related but after 2 years I still have not seen any track results or impressive performance done with any yet. Covid screwed up a lot of folks plans over the last year but come on the tracks were open. I have only seen a mild 400 something horsepower dyno thing that didn't seem to be anything a regular iron D port could do so that's why I am asking. Were halfway to maybe yet another big sale clearance in 6 months from now or so that's why. Thanks
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.3 1/8th pump gas n/a
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
The Following User Says Thank You to PONTIAC LARRY For This Useful Post:
Old 06-23-2021, 05:04 PM
gobrdgo gobrdgo is offline
I’m interested also….
Old 06-23-2021, 08:49 PM
Dragncar Dragncar is online now
By the time you get them the way you want them to be performance and reliability wise you would have 80-90% the money of a good E head. There is that lip just inside the intake port you have to deal with, costs money, time. If you can not get them without the pushrod holes making them a wide port is not cost effective.
America baby.
Old 06-23-2021, 09:13 PM
GTOGEORGE's Avatar
……or hp head, best bang for the buck. Just another option!
GTO George
The Following 2 Users Say Thank You to GTOGEORGE For This Useful Post:
Old 06-24-2021, 09:51 AM
America baby.
Yes , I saw some had to do a good bit of work to improve certain things. This was more also of me just curious to see the results of those that did get them.
Old 06-24-2021, 10:15 AM
Originally Posted by GTOGEORGE View Post
……or HP head, best bang for the buck. Just another option!
GTO George
KRE is my plan still, I am only going to manage to do my new short block this summer maybe KRE swap next year. For me not to have to replace my D port
1.75 headers I lean towards some KRE 310 D ports with 74 cc chamber and that allows me to use my warrior intake (maxed out) or Torker II with about much issue.. Would want to be able to crack the 600+ hp mark .. My new solid roller I got 2 years ago to max out my 270 cfm D-port 16 heads that has not been tried yet is a Howards 261 269 108 .620 .620 so I will see how that does with new short block vs my old solid roller street cam ultradyne 242 252 112 .566 .566 using my #16 heads
Although I really have a boner for the as cast 330 cfm high ports in a 80 cc chamber it would be solid pump gas combo on 93 octane flat top 467 cid but then I have t get new round port headers and probably the recommended intake to match so it snow balls into a S ton of money above the D ports but heck thats a 700 hp set up too
Old 06-24-2021, 02:33 PM
Mike Davis's Avatar
America baby.
Where did you get your info?
I have 2 sets on my bench right now and they look exactly like a Ehead out of the box.
In fact the castings looked better than the 3 sets of Eheads I have.
These heads will go 300CFM really easy with just a sand paper roll clean up, and a little work in the intake bowl. I am sure they will go much more but 300 was all I needed for the combo we are building.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 06-24-2021, 03:46 PM
455dan's Avatar
455dan 455dan is offline
A photo and info from this earlier thread?
Maybe Speed master is stepping up the attention to detail -or the pictured port and insert ledge was only on a few sets?
https://forums.maxperformanceinc.com...68#post6232368
Old 06-24-2021, 04:23 PM
Mike Davis's Avatar
Interesting, The sets I have do not have that step in the port.
Old 06-24-2021, 10:09 PM
Got it right here on PY.
Old 06-29-2021, 02:30 AM
blueghoast's Avatar
I just dynoed my other motor with the speedmaster heads and they
matched my e-heads exactly, And the e-heads have 2.19 It and 1.77 ex.
The speedmasters still have the stock valves in them and less comp. and a
little less flow. I,ll get the pics up of the dyno sheets tomorrow or the next day.
So far I couldn't be happier. 624 hp-597trq the first one made 625.6 hp
and 634 trq. Not bad for a couple of pump gas motors.
GT
The Following 4 Users Say Thank You to blueghoast For This Useful Post:
Old 06-29-2021, 12:38 PM
blueghoast's Avatar
Hope this works It's been a while
GT
The Following User Says Thank You to blueghoast For This Useful Post:
Old 06-29-2021, 12:51 PM
GT
That's quite more like it , as they said they easily hit 300 cfm plus , how much work was done to your out of the box ?
Old 06-29-2021, 01:13 PM
blueghoast's Avatar
Default Dyno Results
Can't remember how to post pics Dag Nab It
GT
Old 06-29-2021, 01:29 PM
blueghoast's Avatar
America baby.
I've got 2-3 time more money in the E-Heads just to match the power of the
Speedmaster heads. I'll be buying the SM heads from now on, I like the
quality A lot better.
GT.
Old 06-29-2021, 03:58 PM
GT.
I have a set I just put on a 455 bone stock out of the box. I was going to match everything up but figured with all haters I was gong to wait and post results with the untouched set. It’s a small hyd roller I put some solid rollers on because I had them. Plan is to have it in car for Norwalk.
The Following User Says Thank You to grandam1979 For This Useful Post:
Old 06-29-2021, 04:02 PM
Forgot this is a $1100 Black Friday set with a $100.00 Black Friday intake gasket matched my me to heads got my fingers crossed.
Old 06-29-2021, 08:24 PM
ponjohn's Avatar
ponjohn ponjohn is offline
GT
What is the whole combo?
Old 06-29-2021, 09:11 PM
GT.
OK, give up the actual number in $ you have in the E heads. CHINESE quality a LOT better ??
4th of July is this weekend dude.
Old 06-29-2021, 10:23 PM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
Which American company did you give your money to? I thought you bought your e-heads second hand?
