I have 2 lists that I looking for information for.
List #1 Pontiac N/A Pump Gas - Door Cars - I did added an E-85 section to this list http://www.magneticlynx.com/carfor/pont_gas.htm List#2 You must be Using PMD Heads and Blocks http://www.magneticlynx.com/carfor/pont_pmd.htm Thanks, Stan
you forgot the E87 section
It is easier to fool a man than it is to convince he has been fooled |
Here you go. I am sure they will be happy with any information you can give them
Common ethanol fuel mixtures https://en.wikipedia.org/wiki/Common..._fuel_mixtures Stan
Cool list!
Aaand now I realize how slow my car really is!
See if I qualify:
1966 GTO / full interior with A/C street car that drives everywhere 468ci / 91 octane / Mick Batson/Les Iden built / Hubbe's 700R4 / 2800 stall Continental / 3.31 rear / MT SS 255/60/15 Comp hydraulic roller 238/244@.050 .590 lift / Harland Sharp 1:52 rockers Crane HIPPO solid roller lifters 310 cfm KRE D ports by SD Performance / Torquer II port matched to KRE heads Ross pistons / 10.5:1 / stock 2 bolt mains, studded / stock iron crank Shaker455 blueprinted 950 cfm Holley with 1" spacer #3750 race weight 11.685 @ 116.2 at Texas Motorplex (slip attached) Best time of 11.62 @ 117 at Amarillo Dragway (no pic of slip)
Mike Iden '66 GTO Post/468, 700R4, 3.31 7.25@96mph 1/8 '21 Chevy 4X4 Crew RST Z71 Last edited by GTO TEX; 12-02-2020 at 01:13 PM. |
![]() Quote:
Stan
91 pump octane
Mike Iden '66 GTO Post/468, 700R4, 3.31 7.25@96mph 1/8 '21 Chevy 4X4 Crew RST Z71 |
Mike,
Thanks, I have added you to the list. Pontiac N/A Pump Gas - Door Cars http://www.magneticlynx.com/carfor/pont_gas.htm Stan
70 firebird
461 stroker 315cfm heads ported by dave Wilcox comp .420 solid roller 276/280 at .050 Ross flat top pistons eagle hbeam rods victor with 1050 dominator on pump e85 turbo 400 3.73 gear 12 bolt. best 9.85 at 135 1/4 mile 6.22 in the 1/8th weight 3395 with driver |
![]() Quote:
![]() Quote:
Stan
I do..can send a pm
Best runs of the year..more left in it..traction was marginal , car has 60 footed 1.47...so more to come next year. Same combo as before but with 373 gears and Prosystems carb.
Update from 1990!
1966 Tempest tube frame. 2620# w/ driver. 406” Pontiac block, crank, rods, heads. 400” block. Self ported #62’s. 389 crank. 455SD rods. Original Wenzler tunnel ram. Best of 10.10 @ 130. MPH. 1.33 60’. NED 1990. 93 octane Sorry, no time slips . . .
" Darksiders Rule "
Guys running my set up are on that list. Makes me happy
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
My set up is 93 octane 9 to 1 compression. 2 bolt 455 w studs and hard block half way , 6x heads, stock cast iron PMD crank, solid lifter cam (I’d have to look up the specs can’t remember them. But it’s a 114 LSA approx 560 lift. Th400 by dynamic trans. , Neal chance converter 10.5 inch, 3000 stall msd 6al2
3250 lb 69 bird stock chassis w mini tubs, 10 pt cage, 373 gear 12 bolt. 315 drag radials , fuel injected. Pro form throttle body, Accel Gen 7DFI and Bosch 160 lb hour injectors . 88 mm turbonetics turbo ( was racin Jason Betwardas turbo once upon a time) 11 PSI boost. Runs 9.70 @146 off the foot brake - Ran the same w the carb as well. Won pontiac day at englishtown first weekend w the fuel injection. Has run the same numbers w a diesel turbo. At same boost.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! Last edited by turbo69bird; 12-03-2022 at 05:13 PM. |
Thank You everyone for the updated information.
The lists have been updated. Please let me know if the information I added was not correct. Stan
Stan, my name is Rob MacLaren, not Eric…..thanks for adding me to the lists!
" Darksiders Rule "
![]() Quote:
My bad. Sorry I looked at the e-mail address and saw Eric. Should be fixed now. Stan
For dyno engines can add the RAV pro stocker.
RAV block stroked to 468 RAV heads Ported by butch Elkins 1970 raced by Stephen Pontiac. Single plane Developmental dual quads 660 center squirters 12.4 compression https://youtu.be/aqGcHD2mnKs
