Windsheild install 1964 GP Question ??
Question....after roping in the shield and gasket....what type of stuff was used to back fill around the gasket....seems like a type of non hardening (plumber putty) type of stuff was in there ,originally. Any help would be great ...thanks.
I have thought that that original stuff looked a lot like bees wax. But I would have smeared some (probably would have used a toilet setting ring to get the wax) on the pinch weld before putting the glass in. On resetting my rear glass I tried what the unsuccessful pros had tried before I did it myself. Some sealer stuff out of a tube that was a real mess to use. You might be able to push some of it in with the glass in place but it will be a mess.
Going to back fill it with 3M strip caulking ...black
It's called nesting compound and kind of hard to find now days. Some newer glass shops don't even know what it is.
Nesting is for door glass, you need the black butyl sealer that comes in a tube and uses a calking gun.
If you use the black urethane sealer don't use too much.An old school glass guy I knew just added a small amount in the 90 degree area of the rubber where it meets the channel.Hard to describe but it's where the bees wax would normally go.You can try with black strip caulk but it doen't have the ability to flow into small voids that you are trying to seal.Also be extra careful as when you pull the rope it doesn't pick up some urethane and spread it around and make a mess. Good question tho.....It's where the old meets the new!
Does that byutal stay soft after years of being in the channel....like the original stuff ?
No,it is a strong adhesive.You don't want to go back in there again.NOT how the factory did it but a somewhat acceptable practice by experienced glass guys.Lots of variables today-is the replacement glass dimensionally correct,how about the aftermarket rubber gasket that holds everything in place,then the mouldings have to go on also and you want it perfect and no leaks?Good Luck!
