detonated
hey just started mixing fuel for my 455 .040 over #12 heads
have been running on race gas 100 - 110 octane now i need to run on pump gas so one ounce of additive to 6 gal of 87 ottane = 96 octane so i put in the first 6 gal NEVER pinged/rattled/detonated that i herd but when i turned it off it ran on for about 3 or 4 sec is that a sign of detonation that i cant hear or nothing to worried about?
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
what additive are you using that turns 87 into 96?
I don't trust these folks any farther than I can throw them. |
Those are good 1/4 times for the 2.56 gear. Must have quite the top end charge.
What cam with the hi compression iron head 455. Run on is pretty common. The question for me is, does detonation occure before or after the normal idle ignition timing.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
A run on problem usually means you are at the bottom of your octane requirement, provided your operating temps, idle speed, and mixture are ok from the start.
How much is this stuff??? must be expensive, they won't tell you on the site.
the fact that im running on 87 octane and his additive and not hearing any nock or ping tells me it is working
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos Last edited by hal101; 02-03-2018 at 01:47 PM. |
i dont hear any detonation at all my only prob is the run on after i turn the key off im just asking is the run on some indication of detonation that i cant hear?
ok so i will move up to 1 oz to 6 gal of 93 octane which = 102 octane and see if it goes away
Won`t hurt to try. Timing has no effect as the spark is off while this is happening. So, it`s out of the picture. The fuel can`t take the heat in the chamber without lighting off by itself. That`s why they called it "dieseling" back in the day.
i could be wrong but that is what i remember
Pre-ignition occurs during the intake stroke, long before ignition. If there is a really hot spot in the chamber, it can light off the a/f mixture as it enters the chamber, while the piston is on it's way down the cylinder. Now, with the a/f burning, the piston starts it's way up the cylinder, compressing the a/f while it's burning. Now the heat and pressure becomes so extreme that it melts the top of the piston, and the pressure blows a hole in it. If an engine pre-ignites, it won't run more that a few revolutions before the piston melts down. This can occur in less than a second. Think about this, at 2000 rpm, the piston is dealing with combustion over 16 times per second.
To answer the OP question, the run on is because the cylinders are hot enough to ignite the A/F as it is still entering the cylinders. This happens with high compression. It can be overcome by shutting the engine off in gear.
Correct. And larger bore engines. That`s why one can get away with less octane, more compression, leaner mixtures, etc, on a Pontiac 350 vs a 455. Especially a modern fast burn chamber aluminum headed 350.
I have found that nozzle drip caused by a to lean idle circuit and too far opened throttle blades are the main issues for run on turning ignition off.
I see this quite a bit with cars that have large cams, and the idle circuits of the carb aren't tuned correctly for the combination, so they struggle to idle, and people kick up the idle speed to compensate, moving the throttle blades passed the idle transition slot. Basically making the car idle off the main jet (nozzle drip) Then complain of poor gas mileage and all the other issues associated with a poorly tuned carb. Last edited by Formulajones; 02-03-2018 at 04:18 PM. |
I don't trust additives at all. You don't really know what they are putting in it, and all you know it is that is making your gas less volatile.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
this may be true but it dose not do it with high octane
That's because the higher octane is harder to ignite. The issue of unburned fuel is still there, it's just that the higher octane masks it because it's not as sensitive to the heat in the combustion chamber.
Hence the reason why higher octane cures detonation, as well as heat soak and vapor lock, and generally also requires more ignition lead for best performance. It's slow burning. |
