Is anyone using a Summit Racing aluminum radiator?
I'm currently in the market for an aluminum radiator. I heard that a 2 row 1.25 core is the way to go. Has anyone used the summit line of radiators? This is the one I am looking at for my 70 GTO.
https://m.summitracing.com/parts/sum-380457
1970 GTO: Atoll Blue, TH400, 400 +.060, small chamber Ferrea big valve fitted # 15 heads, Summit 2802 cam, Iron intake, Cliff Ruffles 850 cfm qjet, Hooker headers, 2.5 mandrel bent exhaust, Race Pro mufflers, 3.73 Safe-T-Track. |
I tried one for my 69 GTO back in 2011. It wasn't a direct bolt in and required some modification so I sent it back.
The 2 row 1.25 tubes is definitely a good choice though. I bought one on Ebay and it works great.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
What was off about it?
I purchased one from champion for my 64. I'm very happy with it.
Patrick -------------------------------- *SOLD * 1971 LeMans street car, 428ci TH350 3:31 12 bolt, 3880#,13.6 @ 101.82 Show & go 1964 Tempest work in progress 400 with Tremec 5 speed 1967 LeMans drop top project. I tracked down my great grand father & dad's old car. |
Im using the Summit aluminium radiator. No issues except for the lower tube was slightly dented during shipping. Causes a small leak. I also had to trim the radiator shroud slightly to get it to fit.
1972 LeMans 461 stroker 10.3:1 Edelbrock D ports Scorpion 1.5 rockers Comp Cams "Stump Puller" roller Holley Ultra Street Avenger 770 Ram Air III exhaust manifolds 2.5" pipes Dynomax VT w/crossover Edelbrock Performer RPM TH350 2.78:1 10 bolt |
Have one in the drag car and it has been trouble free for over a dozen years. No problem cooling the 525 on hot days either at the track.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon. |
I went with a Cold Case. It's a fantastic product, keeps my 469 cool on the street and on the strip.
I bought this one from Auto City Classics. It's is the same dimensions as my current 4 row and it has two 1.125" rows. I'll let y'all know how it works.
I have this as well and it looks to be the same dimensions as the aftermarket brass I took out. I will report back too when the engine is assembled and fired. The fins per inch was 15, compared to the brass aftermarket its sitting in it looks good.
The More People I Meet, The More I Love My Dogs! |
Yep, Ponchjoe. I read your thread about it which prompted me to buy it.
Ok, you go first
I have one in my 67 firebird have had it since 2008 working good, but had to make mounts
Chris Collier 1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans "There is no such thing as too much horsepower" |
I have a Summit "Direct Fit" radiator in my 69 bird. It mounts to the rad support just fine and cools my engine well. It has a built in trans cooler too. However, I had to make a hole in the shroud for the upper rad hose because the width of the rad is a bit narrower than a factory rad. Over all I'm very happy with the quality. It was about $269 back in 2009 IIRC...
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Summit Direct fit with 2000 LS F body Fans and shroud from local junkyard. Works perfectly. Teardown pic, was transferred to a new body.
[SIGPIC] Steve |
