I finally made my decision to go with some Speedhut gauges in my 66 GTO.
I know this has been done before in some way or fashion but I thought that it would be nice to share. I was under a bit of a time crunch to get it done because the car will be heading to the Race Products Expo in Chicago at the end of the month. Speedhut ensured that the gauges would be here on time and they delivered as promised. Let me start this by saying that my goal of this project was to adapt aftermarket gauges to a factory dash with NO modifications to the dash what-so-ever. I love the look of the recessed gauges, just wanted the function of modern gauges. I chose the Speedhut gauges because I could get them made up in any configuration I wanted, the font I wanted and they would fit the openings in the dash pretty well. In order to speed up the fabrication part of this project, I had an old dash that I got out of a lemans years back that used for mockup purposes. The back side of 66 GTO dash is slanted and curved, making it tough to mount a standard aftermarket gauge to the back side of the dash. So, I needed a way to adapt this complex curve to fit the flat surface of the aftermarket gauges. I acquired a junk Lemans speedo and clock panel and I gutted out the gauges, saving the intermediate panel that would serve as the means to adapt a flat panel to the back side of the dash. The 4" Speedhut gauges were used because the ID of the Speedhut bezel is 3 1/2", which is the approximate ID of the factory intermediate clock bezel and the factory intermediate gas gauge bezel. The two factory inner gauges (speedo and tach) have a slightly larger opening of 3 11/16". However, because I chose the Speedhut low profile stealth bezels, I predicted that they would blend pretty well together. I took my dremel and hogged out the existing mounting holes in the intermediate panels and welded some additional pieces to the clock panel to keep it from moving around. I also had to grind some material from the side of the bezel to clear the Speedhut bezels. After some modifications, I media blasted it, primed and used some SEM satin black to match the paint on the dash. ![]() ![]() ![]() I then acquired some 3/16" ABS plastic from Grainger and cut a piece to fit the needs of the gauges. Using some poster board, I transferred the mounting hole locations from the back side of the dash to the paper and then laid these marks out on the plastic. Because the gauge mounting panel is at an angle in comparison to the mounting bosses on the back side of the dash, I used my drill press to drill the holes at a 15 degree angle. This kept me from having to hog out the holes to accommodate the screws going in at an angle. When I started this project, my plan was to make two gauge panels because I had two intermediate panels that I was working with for placing the gauges in the dash and it made sense to install the gauges independent of each other. Here is the first prototype with some cardboard used to layout the marks. After making the first prototype I noticed that the individual gauge panels seemed a little flimsy. Probably because the larger panel only used 4 mounting points. The single panel appears to be a little more stable because it is using all 8 mounting points to support the 4 gauges. ![]() With the mounting holes drilled and double checked for accuracy, I taped a piece of poster board on the front of the gauge panel and installed the panel in the dash. Using a small piece of wood, I taped a piece of pencil lead on to a small block of wood and carefully traced the openings of the intermediate panel on to the poster board. This eliminated any variations that could have occurred when I drilled the mounting holes. ![]() After finding the centers of the marks, I drilled out the mounting holes with a 3 7/8" hole saw that I bought from Amazon. ![]() ![]() Here is a picture of the gauges mounted in the gauge panel. ![]() Some more trial fitting and massaging of the gauge holes were necessary to get the alignment of the gauges just right. Picture of the back side of the dash with the panel installed. ![]() There is a plate behind the ignition switch and the lighter that is used to stiffen and secure the ignition switch and provide a ground for the lighter. Because the factory plate is too big, I had to fabricate one of my own. ![]() Here you can see the spacers required to set the depth of the panel just right so the gauges would mate up with the factory intermediate panel. ![]() ![]() Here is a picture of the dash with the gauges installed. ![]() ![]() ![]() ![]() ![]() The Speedhut gauges are nice quality and the people there are top notch. I think that everything turned out real nice and I will keep on posting as I install them in the car.
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. Last edited by old66tiger; 02-14-2013 at 11:28 PM. |
Nice fab work. The guages look awsome.
Thanks.
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
Awesome work Bob. That looks so much better than the aftermarket plastic flush dashes. The gauges look top notch and the install is super clean. It keeps the stock feel but its modern. Can I bother to ask how much a setup like that will run??
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
Very nice!
Ben R. 2004 GTO - the daily 1966 Olds 442 - the toy 1953 Chevy 5-Window Truck - the heap |
Very nice work! And an excellent post! I'm certain this will be used for reference by many for years to come!
I will be going to the SpeedHut gauges as well for the driver, and at one time, they had the Pontiac arrow logo available on the face. I will have to call and see if that would still be available. (fingers crossed) I like the fact that they offer turn and high beam indicators. Is that a GPS speedo or electronic?
thanks. I love doing custom work. I opted for the gps speedo. I will miss seeing thw speedo hit 60 while standing still, but there is no worry about accuracy and there is some cool timing aspects with the gps stuff.
What happens when you go into long tunnels with a GPS speedo? Always wondered about that. I know that the SpeedHut stuff has some of the fasted startup times, so no worries there.
A friend had a GPS speedo in his WRX, and when he would nail it off the line, and you look down, you could see it sweep up to the current speed. I think the newer ones are much better though, that was a few years ago. I'm going GPS regardless, I can live with the little quarks, if there even is any these days. .
No idea about the tunnels. All gauges work well. Wish the tach had slower re-fresh rates. The GPS speedo increases and decreases a little segmented. But overall, it works well.
Got any pics of the dash installed in the car? Maybe a daytime shot and a night time shot with them backlit?
Great work and i'm thinking of using the Speedhut setup as well,including the GPS setup.From what you done to make this work i'm feeling it would also work on my 65project.You ever thought of doing another adapt plate?
Gotta Luv some old Muscle.. 64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror 3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna Silvermist w/BlackVinyl Top http://s161.photobucket.com/albums/t201/dracowizard/65/ |
Nice work! I am just finishing up my dash. I am using Classic Instruments and the Thunder Road dash. I just finished adding the radio...but no photos yet.
Dave "Big Injun" Anderson dave@4mypontiac.com www.4mypontiac.com For GTO Celebration items click the tile coaster. ![]() |
With the car properly tuned, I have no use for the AF gauge and I really don't use the oil temp gauge anymore. So...Time to re-work the gauges. Beauty of Speedhut stuff is that a re-work of an existing gauge is less than $50. Here are my two paint shop renderings. I am partial to the top one as it is simpler and matches the speedo and tach nicely.
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. Last edited by old66tiger; 12-21-2016 at 10:12 PM. |
I can't tell a difference between the two sets of gauges there.
ButI just ordered the same set up of gauges one the 10th from speedhut. Well same design. I got the dual gauges with water/volt, fuel/oil. It was actually your original post that led me to speedhut. I'm putting them in a 67 but I'm hoping I can make them look as clean as you did. |
Those look really great. I've never heard anything bad about Speedhut.
Fewer tick marks on the top line. Subtle but simple.
Sent from my LGUS990 using Tapatalk
![]() Quote:
![]() Quote:
What option was that to get the fewer ticks? Now that I notice it, I like the cleaner look of it. Sent from my iPhone using Tapatalk |
Custom option...I did it on the first batch
