Old 10-02-2016, 07:09 PM
matth66 matth66 is offline
Ok a pictures worth a thousand words. I started it this morning and it fired up went up to 1900 and eventually with gas peddle help it idled down. The pics are in pretty much cold position
Old 10-02-2016, 07:10 PM
Old 10-02-2016, 07:13 PM
Sorry this is more like cold start position
Old 10-02-2016, 07:14 PM
This is my lifetime project
Old 10-02-2016, 07:49 PM
konwal455gto konwal455gto is offline
Dick is right. Put on a tripower. Great seat of the pants feel and a sound at wot like no other ! Better yet when I had my car appraised the man said the tripower adds 25% value to the car. Truly a win win. konwal455gto
P.S. Have Dick build it you will not regret it!
Old 10-02-2016, 08:39 PM
Just tried firing it up again and couldn't keep it running without keeping my foot on the gas
Old 10-02-2016, 09:46 PM
If I am looking at your pictures correctly, it appears that your screw never did go up on the high step of the cam.
I thought where the line is on the cam is where the screw should set when the gas pedal is first pushed down before the engine is started.
Have not worked on an AFB in quite a few years, maybe Jon and others can agree or disagree with my recollection.
Old 10-02-2016, 09:57 PM
Dick Boneske's Avatar
Yes, you can shut off the warm engine. Open the throttle slightly, hold the choke flapper shut. While holding it shut, close the throttle to idle position. Release the choke flapper. Then, you can start the engine with the fast idle cam in the full choke position. This allows you to set the idle just as you want it to be.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 10-03-2016, 01:03 AM
Tom-Ya it never seems to go to the same spot twice
Old 10-03-2016, 04:07 AM
Kenth's Avatar
Kenth Kenth is offline
Originally Posted by matth66 View Post
I'm a little in clear how to set the fast idle once engine is warm? Do I manually put fast idle screw on the lobe at the spot for cold start?
With cold engine, open the throttle to set the chokeblade closed.
If adjustment needed, losen the three screws at choke cover and turn cover to have the choke blade just closed, no more no less.
With choke blade fully closed check that fast idle screw touches the fast idle cam at the mark on cam. To adjust bend the rod to the choke blade.
With engine completely warmed up and fast idle screw on highest step of fast idle cam, at mark, set fast idle screw to give an Engine speed of 2500 rpm´s.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-03-2016, 08:38 AM
STEELCITYFIREBIRD's Avatar
Picture from post #23, the secondary lock out is not engaged. But in post #22, pic 3 it is. ?? Time for a little lube perhaps? Maybe that will make for more consistent fast idle cam positioning.
Old 10-03-2016, 08:53 AM
carbking's Avatar
carbking carbking is offline
Lubrication on carb linkages normally causes more issues than it fixes.
I saw the secondary lockout issue as well, but believe it is due to improper adjustment.
If the OP will read and follow Kenth's procedure (a couple of posts above this one), things should be good.
Jon.
Old 10-03-2016, 10:14 AM
I will give that a shot. I'll keep you guys posted
Old 10-03-2016, 03:38 PM
77 TRASHCAN's Avatar
Where can that aluminum air cleaner adapter be bought?
Shut it off
Shut it off
Old 10-03-2016, 07:09 PM
Sorry trash can, one of a kind. My uncle is a machinist and he made it for me
Old 10-03-2016, 07:12 PM
Ok so I re-adjusted and bent the rod slightly to get to the mark here is where the carb sits dead cold
Old 10-03-2016, 07:58 PM
You are sneaking up on it. GREAT JOB.
That AFB will START and run smooth like a top when you are finished with talking to the PY people.
  #38
Old 10-03-2016, 08:15 PM
Ok so after 2 pumps it fired up smooth, you guys are awesome!!!! Where were you people when I was 15 trying to get it running:-) the internet is a wonderful place
  #39
Old 10-03-2016, 08:17 PM
The only thing I haven't adjusted was the fast idle when warm. It's set at about 2000 right now, I just can't imagine increasing it to 2500. Seems really high! Also I'm idling when warm at around 800 think I'll try dropping it a little, factory is 600 but I have a mild cam
  #40
Old 10-04-2016, 12:58 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Normally the vacuum pull off and a tap on the pedal should pull it off the high step right after start up.
But i dont see a pull off in pic's.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
