#81
I ended up with 3 (approx 3/8" total) washers under both transmission mount bolts (crossmember) to get under 3 degrees down (up in front, down in back) which is where you want to be. I am now much closer to the trans tunnel and would have altered my opening initially had I known I'd needed to come up more.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#82
Breaking news...overdrive cut gears for muncie transmissions
http://autogear.net/ag_archive/literature2.htm# |
#83
Lol.... no kidding. I am one of the ones hijacking! Problem is...you can buy a TKO 500/600 for 2500 bucks or so - but the "perfect fit" business might cost another 1000!! Upping to a 5speed seems more expensive than I originally thought. |
The Following User Says Thank You to GTOLou For This Useful Post: | ||
#84
Try starting the swap with a Turbo 400.........
#85
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
The Following User Says Thank You to GOAT WHORE For This Useful Post: | ||
#86
Not to mention I don't know of a single person who has used it. Last update on that site for that setup was like 3-4 years ago...
#87
Said it was for a 4.11 rear gear and would produce a final drive equal to a 3.55 in 4th. Not an overdrive at all.
#88
I'm running a M21Y gear set in my 70 GTO. The OD is .86:1 and make my 3.90 rear look like a 3.36 in 4th (OD). Not a real big reduction but enough to reduce 400 rpm at 60 mph. The only thing you have to get used to is the large ratio change from 2nd to 3rd (which is the old 4th gear) and the small ratio change from 3rd to 4th (old 3rd gear now an overdrive). If I had to do it over again, I would have kept the M22 and change the rear to a 3.55 or changed the Muncie to a M20 gear set and find a 3.31 or 3.23 rear. I believe Tom S had one in his Trans Am and if I recall correctly he liked it.
#89
X2! That thing would feel similar to an SROD trans.
___________________________________ "Objects in mirror are closer than they appear" |
#91
[QUOTE=jonathonar89;5121577]I admire 5 and 6 speed transmissions but I'm also going to be trying out a weird 4 speed setup. 2.64 T10 trans with a 2.73 10 bolt rear in my firebird. I also plan on changing to a shorter 275/40 17 (25.7" tall) tires so that's a changing factor in my equation.
[/QUOTE When I first switched from auto to manual I had a Saginaw 4 speed with a 3.11 low gear and a 2.56 rear end. It actually drove out pretty well. Both the tranny and rear end had issues however so that combo did not last long.
1969 Firebird 350 convertible, t-5, Carousel Red 2008 Solstice GXP 5speed manual, Sly 2008 Grand Prix, Ink Slate, Winter daily driver 2009 G8, Switchblade Silver, summer daily driver |
#92
Was there variability on how far back you moved your crossmember or did you move it the exact proper amount and yet it still requires some shimming to get proper geometry ?
-Jim Doran- 1965 389 Tripower; 4 speed; convertible 2019 Tesla Model 3 Performance 2016 Chevy SS; Sold 2001 Toyota Tacoma 4x4 2008 Infiniti G35x |
#93
The problem angle is in the transmission output shafts relation to the pinion angle. As my trans sat on the mount and it sat on the crossmember, the trans output shaft was 4.5ish degrees (down at the rear...from memory here...) and needed to be less than 3.
#94
I see on the Pro-touring forum that the driveshaft shop offers a cv style shaft that takes the u joint angle problem out of the equation. Pricey solution but it is pretty cool.
Sent from my SCH-R970 using Tapatalk
Skinned knuckles and empty wallet! Could I be any happier? 66 GTO Convertible. LS3-525 HP. Legend LGT700 5-speed, Wilwood 4-wheel disc brakes, Ridetech coil over front susp, PMT rear susp, Hotchkis bars, Billet Specialties 18" Dagger's (18X9 rear, 18X8 front). 2002 Ram Air WS.6 convertible Trans Am. Wife's car. |
#95
#96
http://www.pro-touring.com/threads/4...=cv+driveshaft. Go to page 28
#97
The carbon fiber deal was a bit more expensive, but I think this guy is willing to spend the extra. An aluminum version is about $900 if I recall correctly. Pricey, but if it solves the problem, it's worth it.
#98
Thank you
Charles
