#81
#82
John Marcella Marcella Manifolds Inc. john@marcellamanifolds.net ph. 248-259-6696 |
The Following 2 Users Say Thank You to john marcella For This Useful Post: | ||
#83
My e heads was done by butler, they was as big as they could go without being wide ports and I know everyone has their own situation and preference but in mine I had more money in my e heads than I have in my whole top end right now (long story) the e heads can make power but so can the tigers,wenzlers,and CV1. I am happy that there are options out there, I also had some casting issues with the e heads. We actually cracked one around a head stud and it would leak water lol but I am not bashing the e heads I liked them and hauled ass with them but I like my CV1s and have hauled ass with them and I really believe when I soften the chamber a little and do the convertible exhaust to help get heat out I will go faster. To me the CV1 is a good na head and can be a great nitrous head with a little work and still be more cost effective than Tigers or some of the big excotic heads.
#84
But thought that was beat to death on YB.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
The Following User Says Thank You to LiL Jack For This Useful Post: | ||
#85
Worst thing with making big power with a Pontiac is the two center exhaust valves next to each other and the thin wall on big bore motors, oh and only have ten head bolts!! But again we must adapt and over come!!
#86
HFS and well done bro! :-)
#87
Congrats Kendall on the race.
Good to see a Pontiac in the front
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
#88
Thanks Doc! I really didnt expect this thread to take a turn like it did but it did.
Thanks Guys who gave my friend Kendal the high five he deserves it!The ones that know how tough it is to get a pontiac to run a number.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.82@159.91 in Joliet May 2024 ….157.56 MPH in Gainesville in March ‘23 |
The Following User Says Thank You to S/st 54 For This Useful Post: | ||
#89
Well, I was going to say comparing a 330cfm inline head to a 380cfm canted valve head with a big head is a joke, but we all beat that horse to death!
Just sayn!
#90
Ok I take it back man. I thought you really wanted a set of Warp 6 heads but 7 hours and 18 minutes is a step in the right direction. Keep working on it! Lol
380 cfm is flow area, canted valves or not. The only thing canted valves provide is more flow area on a small bore where you can't put larger valves with an inline head. Inlines have done 450 so canted heads should have higher flow potenial but you have to have yhe cid and rpm to utilize them. Last edited by Aaron Quinton; 10-15-2013 at 09:41 PM. |
The Following User Says Thank You to Aaron Quinton For This Useful Post: | ||
#91
Hoax??? Jack... I'll try to give you some insight on the convertible exhaust... when exhaust valve first opens there is a release of pressure and exhaust gas both are very high pressure and velocity... it takes less energy to go straight for a bit than be forced to turn right past the valve... our traditional droop snoot hasnt shown up as an advatage for the big boys in pro-stock or comp eliminator so I think there is merit in having a high ex port exit as that seems to be the trend in non Pontiac race cylinder heads. Another thing the convertible exhaust does is put a good amount of exhaust heat ABOVE the centerbolt...heat rises... Convertible exhaust or std cv1/Pontiac ra4 style exhaust, the cv's also have a cooling vein on the center bolt boss that also helps pull heat away from the center bolt boss. CV2 with convertible exhaust is better idea yet... wish Jim could be convinced to cast some in re-tool port configuration... |
#92
#93
Which # port is the retool port?
#94
When are we going to see you post CV1TTFMF???
#95
I think he has to race first???
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
#96
jack you cant get Warps,Cv'1s or Cv2's. LMAO!!!!
get the Visners!!!!!!
#97
There you go Jack... maybe Visner doesnt know of you yet.
#98
I've wanted CV2 all along.... it was on the drawing board first... I think he got talked out of that because of cam/header change adding cost to consumer... plus didnt want to step on McCartys V project at the time...
Which #?...I lost count Jack, I got a cheap calculator... but re-tool port is starter level with more material to accomodate 500+ without adding material. re-tool as cast port "only" goes 414 at .950" with a 2.125 valve, 328 at .500", 297 at .400" Let this thread go back to Kendall and not head games. Hookin up an 8.5 tire is no easy task. |
#99
I want an LS3 style head for our Pontiacs. If the CV2 has that layout, great!
#100
Why would he? The rest don't. Heck half don't even own cv1s that love on them so much!
Ya, I know.....But I couldn't resist......It was right there waiting to be said.
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
