WELCOME!
Old 10-10-2013, 03:04 AM
GTOJOE228's Avatar
GTOJOE228 GTOJOE228 is offline
Default Passenger window problems
Not sure if anyone has run into this.
Seems the window glass has some type of
a tab on both ends to ride up and down the
window track. Once they are somehow broken
off the problem starts with the window going up and down.
Any advice?
1966 GTO Conv't, 4-speed, Tri-Power(sold)
1967 GTO Ram Air, PHS Doc. 4sp, #'s match, 15+ options 1 of 751
(Featured on Cover plus 6 page spread in May 2006 HPP)
1970 GTO Judge, PHS Doc. 4sp, #'s match, Ram Air III
2006 GTO Spice Red. M6,18" wheels, 400 HP LS2
richmondcountypontiac.com
Need High Quality Printing fast and reasonable?
www.farbetterprinting.com
Since 1974
Quotes at: sales@farbetterprinting.com
Old 10-10-2013, 09:41 AM
Sirrotica's Avatar
Any advice?
This is a common problem and happens with both windows. I need to repair my own right window as it's also off the track and binds up.
BE AWARE that rolling the window down after this happens will unlatch the door. I have already had my door swing open in traffic while braking, or turning left because of this.
What happens is the bonding agent that holds the channel to the glass becomes un-bonded and causes the jamming. GMs repair is to replace the window and track to the tune of $700-$1000.
The DIY fix is to get the regular JB weld and mix it and re-bond the glass to the channel and raise the window in the door for 24 hours as it dries to position it and clamp it in place using the window regulator as the clamping force. The DIY repair costs about $5 plus and an hour or so of your time to remove the door panel and clean the surfaces to be bonded together.
The quick dry JB Weld is not recommended for this repair as the bond is not as strong as the regular JB Weld. I hope this helps you with the problem.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Featured Vendors
Advertising Info
