strange ticking noise
just wondering if anyone else has run into this strange problem,I now have had a 74,75,76,78 and a 79 that all have had this weird engine like tick noise but no noises heard at the engine, this is going to sound crazy but it sounds like the ticking is coming from the rear of the car changes with rpm comes and goes while driving, it seams to go away slightly when warm,common issue with all 5 cars is exhaust system replacements and the 76,78 and 79 had rocker adjustments, any idea's really confused ? thanks
1973 super duty trans am |
The speedo cable can make a ticking noise that will change while driving.
Im sure that is not the noise. i am aware of that one this is a very loud metallic tick and the noise is definitely coming from the back of the car,but thanks
I'd say that your exhaust gaskets are wearing out!!
I'd say that your exhaust gaskets are wearing out!!(the ones between the head and exhaust manifolds)
wouldn't that give me some kind of sign at the engine i.e tick and a definite leak,but i have nether at the engine ,i just don't understand whats going on here,the noise is with out any question coming from the rear of this car.
Thats a difficult thing to try to hone in on without sticking your head under it and actually hearing it yourself,,, Is it a rhythmic tick ? or is it kind of random? could it be something expanding on something on the exhaust?.Pipe close to the frame? If its with the car not moving it must be related to the exhaust in some way, or sound echoing from the front, Do you have an electric fuel pump back there?,
This is really reaching but maybe loose heat riser door in manifold slapping with broken spring, Don't even know if your car would have something like that, probably hear that under the hood . Just thinking of what could echo out in the rear. Its the unusual sounds that make you have to think of unusual problems.
Because we can't hear it it's hard to figure it out, but have you though it may be loose baffels inside the muffler causeing it.
My 69 Olds will tick like you are describing. Comes from the rear only when cold, it is not exhaust and is varies with rpm. Goes away quickly once car warms up. While laying underneath listening, it sounds like it is coming from the fuel line. Sounds strange I know, but can pumps tick when cold? Seems like the sound transfers down the line as I can here it all along the frame rail where the line runs, but is loudest at the rear.
Living in Tucson, it is rare that it is cold enough to occur very often, so have never pursued further diagnoses as it won't make the noise other than the coldest morning. I am still curious to the cause. |
