#61
Saw the car at SEMA but the hood was closed so I had no idea what was under the hood. Didn't even notice some of the subtile changes until looking at the pictures here. Very nice car and it sounds great.
Matt Luster |
#62
I apologize for the delay. Here are the final build specs:
Cubic Inch - 454 Block - IAII cast iron 4.250" bore. Mains - billet 3.00" splayed mains, Crank - 4.00" stroke crank - Scat 4340 forged steel Rods - 6.800" Eagle - Forged H-beam rods with ARP2000 rod bolts Pistons - Ross custom 8.5:1 compression ratio forged dished pistons Rings - Total Seal piston rings .064"top .064 2nd, .188" oil Bearings - Federal Mogul bearings H-series Heads - Kauffman - CNC ported 380cc high port aluminum heads assembled complete Rocker arms - Harland Sharp aluminum roller Head Gaskets - Cometic MLS .040" head gaskets Cam - Comp Cams custom ground hydraulic roller turbo cam with All Speed Customs specs furnished Comp Cams Lifters - Comp Cams hydraulic roller lifters Push rods - Engine Pro .083" wall chromoly pushrods Pan - Canton- 7 qt. deep road/drag race pan with pick-up Oil Pump - Melling HV ATI- Super Dampner |
#63
The valve covers, intake and throttle bodies were custom made by Visner Engines out of Lowell, MI. Dave Visner is a long-time racer and true craftsman.
#64
I just posted the build sheet. Nothing corporate about this build - a Pontiac build up all the way! |
#65
Now that's a PONTIAC!!!
Typically around here if it's doesnt' have Rally II wheels or the correct color Pontiac Blue you are suspect. :-)
"Everyone is entitled to be stupid sometimes, but you're abusing that privilege" www.musclecarsgalore.com www.nikivee.com [www.reverbnation.com/nikivee 1967 Pontiac GTO 1967 Pontiac Grand Prix 1972 Pontiac Lemans Sport Convertible 2015 Dodge Challenger ScatPack 392, 6 speed 2017 Ford Explorer AWD |
#66
One of the nicest cars I have ever seen! I would love to make my 92 firebird like this. The black on black is so cool, Pontiac engine and turbos! I love everything about this car.
#67
What size are those intercooler cores? Can you post a few pics of them out of the car?
Thanks, |
