1970 Firebird Twin Turbo
Hello. I am a new member to this forum and wanted to share a build I just completed prior to the SEMA show last fall.
We recently put the engine on a resistance dyno to completely dial it in. It produced 1012 hp and 950 lbs/tq at 5600 rpm and 12.72 lbs boost and pump gas. I think we’ll keep it there for now as I learn how to drive this beast. Here’s a link to that dyno pull: http://www.youtube.com/watch?v=GsNyy...&feature=email Here’s also a tour of the finished product: http://www.youtube.com/watch?v=f93GC...eature=related Let me know what you think. Thanks! |
Without having to watch videos, what engine is in your car? block? heads? crank? intake? etc.
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
I think the craftsmanship looks well-thought out. Styling points are cool. As if the shop was capable of Limited Production.
I assume the 1/4 mile times will be QUICK, yet stick-driver dependent into the 8's. Can that Keisler Stick handle the 1000HP? I mean with traction or Hop? 10" fronts 12" rears; can it autocross?, or GT across the U.S.? |
Here's the engine specs. and a few shots of the engine bay and video of the first time driving.
Engine - 475 Cu. In. Custom Twin Turbo Pontiac AI2 cast iron performance Pontiac 400 block Eagle forged 4340 crankshaft Eagle H-beam forged connecting rods Ross custom forged pistons 8.5:1 compression ratio Comp Cams Hydraulic roller camshaft (All Speed Performance turbo grind) Comp Cams hydraulic roller lifters Kaufman KRE 340 CFM aluminum cylinder heads Stainless steel Ferrea valves Comp cams valve springs and retainers Comp Cams Chromoly pushrods T&D shaft mount Rocker arms Comp Cams billet adjustable timing chain Melling high volume oil pump Canton racing high capacity oil pan and pick up Custom Visner Engines intake with dual fuel rails Custom Visner Engines dual throttle bodies with 4" openings Billet Specialties accessory drive Aluminum radiator SPAL dual 11” fan Stainless bolts and hardware Turbo system – Custom All Speed Performance Twins2 ea. Bullseye Power 62 mm extended tip turbos with polished race covers 2ea. Tial 44 MM v-band wastegates 2 ea. Tial 50 MM blowoff valves Custom air to air intercooler with aluminum charge tubing Custom air hat with retro-Pontiac six pack design Fuel System Rick’s Stainless tank custom spec Aeromotive Eliminator fuel pump with dual filters Aeromotive fuel pump controller Aeromotive stainless lines with aluminum reusable fittings ExhaustCustom stainless steel headers and 3.5” stainless steel exhaust with x-piping Custom rear-exit exhaust manifold Drive TrainTremec TKO 500 5-speed manual transmission RAM Dual disc racing clutch Moser 12 bolt rearend Truetrac 33 spline axles Moser Pro-Street gears Suspension and Brakes DSE tubular upper and lower control arms with 2 ˝” drop DSE 600 performance steering gear DSE tubular tie rod adjusters Delrin bushings QA1 adjustable coilovers DSE rear Quadra Link suspension with adjustable coilovers and 3” drop Wilwood 6 piston calipers with 14” drilled and slotted front rotors Wilwood 4 piston calipers with 14”drilled and slotted rear rotors Wilwood aluminum tandem master cylinder Wilwood proportioning valve and stainless brake lines Hydroboost power brake system |
Very nice combo!
I guess I'll take you at your word as I cannot recognize anything Pontiac in there ( is it just me?). valve covers, heads, alt mount, belt, etc. could be anything under there.
Congrats on your power accomplishments.
""""""Ross custom forged pistons 8.5:1 compression ratio"""""" ::::We got the SAME slugs. Nicely done.
""""""Tremec TKO 500 5-speed manual transmission"""""" :::: Video says keisler transmission, so guessing THAT didn't last long?
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Jesus Christ, Steve. It's NOT a corporate engine. The video clearly shows from the passenger side of the block that it has traditional Pontiac cylinder heads. Why would he make up all of that data if it weren't a traditional Pontiac?
BTW a very nicely executed and well thought out car and it looks as if the craftsmanship is excellent!! |
Have you ever built anything custom? Way to welcome him A.H.
Wow a lot of custom stuff in there. I can appreciate the amount of work that went into that. |
1959-1980 Pontiac Window Sticker Reproductions : http://www.pontiacwindowstickers.com My Bio: I am currently writing articles for POCI's Smoke Signals magazine and enjoy promoting and discussing the history of the Pontiac Motor Division. |
We need people to make intakes like that for the masses.
The car looks to be very well thought out and executed. What are you doing about air filters? I like the custom bodywork touches to the roof and deck area. Fender treatment behind the front wheels is not my cup of tea, but works with the overall "road race" look of the car. Definately a road car and not a drag race machine, but 9 second timeslips wouldn't be out of the question. A coworker of mine owns a mid-90's Lexus 4-door with one of those hot-rodded Supra engines that is set up similar to this, and was dyno'd at over 800-HP with a race gas tune...he's been 10.50 @ 140-MPH with it, granny shifting it and launching easy.
Relax people, all I said was I could not recognize it in the pics. Did not say anything bad.. I even complimented on the power output. and no, I guess I have never done anything 'custom'. calm down now. if I am wrong, show me in the pic where I can recognize it, that is not a good or a bad thing, just a fact.
Real class there. So, if I do not agree with you, that makes me an 'a h'? What would it make yourself? You are a bit touchy
The man asked my opinion and I gave it. simple simple
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 Last edited by Steve Barcak; 02-06-2011 at 03:15 PM. |
wow, did you do all the fab work? very nice install. welcome to the jungle too!
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I agree is it very nicely built. Also said I take him for his word. That is a compliment. The craftmanship is excellent and admirable as well.
Wow, nice car! You spent a lot of time just sorting out everything I'm sure!
love the turbos
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
Holy !"()/# ....... Nicely done! Love all the details.
Kris.
*** THE BIG BRACE is here *** |
