Oil containment for a Drag Race car!
Just wondering about pros and cons......im thinking of going to a belly pan from my engine diaper. What are racers thoughts?
GTO George |
most do run pans
I ran a diaper for a while and it was a real pain.
Built a belly pan that can be removed with 4 dzus buttons and is so much nicer |
The Following User Says Thank You to racegto65 For This Useful Post: | ||
Pics if possible! Thanks, George |
A belly pan is great, HOWEVER, if things eventually go south (and it happens), please remember to make SLOW TURNS after it blows up. A friend of mine lost his engine at Norwalk. Belly pan contained everything, but when he made the 90deg turn to line up with his trailer, about 5-6 quarts sloshed out of the pan!!! It was one hell of a mess to clean up.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
The Following User Says Thank You to Mr Anonymous For This Useful Post: | ||
Beat me to the post, Mr Anonymous.
Really good advice which I would not have considered. Tom V.
I just had a pan built, so much easier and takes 2 minutes to pull off. I had the walls built 5 inches tall, had to notch a few spots to clear limiters, belt drive ect. I will have to take some pics.
Dave Polichena |
The Following User Says Thank You to Dave Polichena For This Useful Post: | ||
Also have a pan with 4 dzus fasteners. Make the sides as high as possible. Sorry I don’t have pics. Car is home. We are in Florida for the winter.
The Following User Says Thank You to aaronman For This Useful Post: | ||
GTO George |
GTO George |
Thanks, GTO George |
A couple of pics from my car.
The first pic is how low my oil pan is to my frame, the second is the limited space between my flywheel and oil pan . GTO George |
As long as you headers are outside the frame rails, belly pans work great. Otherwise a diaper is needed
The Following User Says Thank You to slowbird For This Useful Post: | ||
I was thinking of fabricating it out of steel instead of aluminum, just in case a rod or whatever decides to exit the oil pan. I plan on bolting it to the engine and frame…… just thinking!
GTO George |
Before you put it on, fill it with the amount of oil the pan holds - and check it out. Maybe fold the upper sides in to prevent sloshing?
GTO George |
For a given thickness, aluminum wrought alloys are as "blast resistant" as steel. In some instances even better, due to the extra energy absorbed to deform the aluminum.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
Belly Pan
Check the rules on the thickness of the pan, thinking is has to be .050 or something like that. The pan goes rail to rail. I have full circle mid plate and it bolts to that on the back. Welded a couple tabs on the sides up front.
Dave Polichena |
I’ve seen some pans with absorbent type material such as pig mat in the bottom of them.
Make sure it is glued or secured in some fashion, the stuff makes a real mess when it comes loose and melts around the header tubes.
Thread Tools | |
Display Modes | |
