Old 12-09-2021, 04:36 PM
GTOGEORGE's Avatar
Default Oil containment for a Drag Race car!
Just wondering about pros and cons......im thinking of going to a belly pan from my engine diaper. What are racers thoughts?
GTO George
Old 12-09-2021, 06:06 PM
cgeise's Avatar
cgeise cgeise is offline
most do run pans
The Following 2 Users Say Thank You to cgeise For This Useful Post:
Old 12-10-2021, 12:47 PM
racegto65's Avatar
racegto65 racegto65 is offline
I ran a diaper for a while and it was a real pain.
Built a belly pan that can be removed with 4 dzus
buttons and is so much nicer
The Following User Says Thank You to racegto65 For This Useful Post:
Old 12-10-2021, 03:11 PM
GTOGEORGE's Avatar
Pics if possible!
Thanks,
George
Old 12-13-2021, 09:48 AM
Mr Anonymous's Avatar
A belly pan is great, HOWEVER, if things eventually go south (and it happens), please remember to make SLOW TURNS after it blows up. A friend of mine lost his engine at Norwalk. Belly pan contained everything, but when he made the 90deg turn to line up with his trailer, about 5-6 quarts sloshed out of the pan!!! It was one hell of a mess to clean up.
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
The Following User Says Thank You to Mr Anonymous For This Useful Post:
Old 12-13-2021, 12:35 PM
Beat me to the post, Mr Anonymous.
Really good advice which I would not have considered.
Old 12-13-2021, 01:24 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
I just had a pan built, so much easier and takes 2 minutes to pull off. I had the walls built 5 inches tall, had to notch a few spots to clear limiters, belt drive ect. I will have to take some pics.
Dave Polichena
The Following User Says Thank You to Dave Polichena For This Useful Post:
Old 12-13-2021, 01:41 PM
aaronman aaronman is offline
Also have a pan with 4 dzus fasteners. Make the sides as high as possible. Sorry I don’t have pics. Car is home. We are in Florida for the winter.
The Following User Says Thank You to aaronman For This Useful Post:
Old 12-13-2021, 04:27 PM
GTOGEORGE's Avatar
Thats what i was thinking!
GTO George
Old 12-13-2021, 04:28 PM
GTOGEORGE's Avatar
I would love some pics! Thanks1
GTO George
Old 12-13-2021, 04:29 PM
GTOGEORGE's Avatar
I was thinking of a DEEP belly PAN/Diaper set up!
Thanks,
GTO George
Old 12-13-2021, 04:31 PM
GTOGEORGE's Avatar
A couple of pics from my car.
The first pic is how low my oil pan is to my frame, the second is the limited space between my flywheel and oil pan .
GTO George
ID:	579575   Click image for larger version
Old 12-13-2021, 04:43 PM
slowbird's Avatar
slowbird slowbird is offline
As long as you headers are outside the frame rails, belly pans work great. Otherwise a diaper is needed
The Following User Says Thank You to slowbird For This Useful Post:
Old 12-13-2021, 05:22 PM
GTOGEORGE's Avatar
I was thinking of fabricating it out of steel instead of aluminum, just in case a rod or whatever decides to exit the oil pan. I plan on bolting it to the engine and frame…… just thinking!
GTO George
Old 12-13-2021, 06:05 PM
GTO George
Before you put it on, fill it with the amount of oil the pan holds - and check it out. Maybe fold the upper sides in to prevent sloshing?
Clutch Guys Matter
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 12-13-2021, 06:21 PM
GTOGEORGE's Avatar
Oil pan holds 12 quarts of oil.......LOL!
GTO George
Old 12-14-2021, 02:14 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... I was thinking of fabricating it out of steel instead of aluminum, just in case a rod or whatever decides to exit the oil pan...
For a given thickness, aluminum wrought alloys are as "blast resistant" as steel. In some instances even better, due to the extra energy absorbed to deform the aluminum.
Old 12-14-2021, 02:18 PM
Default Belly Pan
Check the rules on the thickness of the pan, thinking is has to be .050 or something like that. The pan goes rail to rail. I have full circle mid plate and it bolts to that on the back. Welded a couple tabs on the sides up front.
ID:	579623   Click image for larger version
Name:	Oil pan belly.jpg
Dave Polichena
Old 12-18-2021, 03:44 PM
janderson's Avatar
janderson janderson is offline
I’ve seen some pans with absorbent type material such as pig mat in the bottom of them.
Make sure it is glued or secured in some fashion, the stuff makes a real mess when it comes loose and melts around the header tubes.
