Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 2
1
2
Showing results 1 to 25 of 32
Search took
0.02
seconds.
Search:
Posts Made By:
chaosrob
Forum:
70-72 GTO Tempest & LeMans TECH
08-27-2023, 08:14 AM
5
Seat upholstery question
537
Posted By
mrennie
Legendary makes good stuff. I bought a...
I bought a complete interior kit from them for my 70, and it took me 3+ years to get around to doing the seats. When I did the back seat, I found a defect in the...
Forum:
08-27-2023, 06:00 AM
5
537
Posted By
tigergto
When I redid my 71, SMS were the only ones that...
When I redid my 71, SMS were the only ones that had the original material. Legendary was close, but when I held the samples next to each other I could see the slight difference.
Forum:
THE LOBBY
08-23-2023, 08:39 AM
36
Update on the 1971 455 HO car I bought from Franks
2,437
Posted By
Skidmark
Huge difference. Looking good.
Forum:
THE LOBBY
08-23-2023, 08:16 AM
36
2,437
Posted By
Half-Inch Stud
Yea, that is progressing nicely.
Forum:
THE LOBBY
08-23-2023, 07:55 AM
36
2,437
Posted By
OCMDGTO
Looks great, quite a before and after
Forum:
THE LOBBY
08-23-2023, 06:10 AM
36
2,437
Posted By
JSchmitz
Nice!
Nice!
Forum:
01-29-2023, 08:01 PM
5
Suspension question 1971 455HO GTO
905
Posted By
SD455DJ
Nope, they are the same size as the 'regular'...
Nope, they are the same size as the 'regular' GTO's. The big bars came on the '72 GTO's with the WW5 option.
Dennis
Forum:
70-73 Firebird & TA TECH
05-14-2021, 05:18 AM
3
Formula Ram Air Question
1,288
Posted By
nas t eh
Any 70 -75 formula hood can be used as a starting...
Any 70 -75 formula hood can be used as a starting point. The factory RamAir hoods have the front opening cut open, a screen installed in each one to keep debris out and the rubber accordion boots...
Forum:
74-76 Firebird & TA TECH
05-09-2021, 09:18 AM
9
Preferred Carb base gasket 1976 Trans Am
2,544
Posted By
burd
No gasket on the stainless shield if you have one.
Forum:
05-08-2021, 11:54 PM
9
2,544
Posted By
Aus78Formula
x2 although not a Pontiac engine here, I find...
x2 although not a Pontiac engine here, I find the thickest stock versions were the best, also for insulation purposes and those that include the nylon crush inserts.
Does yours also include the...
Forum:
05-08-2021, 07:41 AM
9
2,544
Posted By
77 Canamman
Fel-Pro has worked for me in the past. ...
https://www.autozone.com/fuel-delivery/carburetor-mounting-base-gasket/fel-pro-carburetor-mounting-base-gasket-60397/67560_0_0
Forum:
05-05-2021, 10:10 AM
15
1976 Dash/vin questions
4,035
Posted By
Aus78Formula
Interesting. I only have a few saved photos of...
Interesting. I only have a few saved photos of this style. I was trying to work out if they'd extended the opening cut to cover the rivet holes but it seems nicely pressed with lip still.
I...
Forum:
Pontiac - Race
04-27-2021, 10:52 PM
11
Plug to seal factory dipstick tube location
2,643
Posted By
CraigG.
Worked great for me - if I have a leak or wonder...
Worked great for me - if I have a leak or wonder - I just get out the dip stick!
Forum:
Pontiac - Race
04-27-2021, 04:56 PM
11
2,643
Posted By
BB70
I used a small cup plug- freeze out plug.
Forum:
Pontiac - Race
04-27-2021, 12:35 PM
11
2,643
Posted By
ta man
I did the same and used the "Right...
I did the same and used the "Right Stuff"
Forum:
Pontiac - Race
04-27-2021, 07:40 AM
11
2,643
Posted By
Half-Inch Stud
When i plugged the Dip-tube hole; JB Weld and a...
When i plugged the Dip-tube hole; JB Weld and a randon bolt for filler, them masking tape to shape the surface during cure. The Billet Caps motivated the plugging due to inteference with the tube...
Forum:
Pontiac - Race
04-27-2021, 07:04 AM
11
2,643
Posted By
ErikW
I usually just make an aluminum slug to drive...
I usually just make an aluminum slug to drive into the hole from the outside.
Forum:
Pontiac - Race
04-27-2021, 02:44 AM
11
2,643
Posted By
lust4speed
When rebuilding an engine that we knew a Canton...
When rebuilding an engine that we knew a Canton pan with it's own dipstick was going in I cut a 1" long piece of half inch rod and stuck it in the block with Ultra Grey. Pushed it in to the bottom...
Forum:
Pontiac - Race
04-26-2021, 06:25 PM
11
2,643
Posted By
tom s
I actually made mine work with a tip from a board...
I actually made mine work with a tip from a board member.Too late now I guess for you.Tom
Forum:
Pontiac - Race
04-26-2021, 06:10 PM
11
2,643
Posted By
Kevspontiacs@aol.com
I just put a rubber plug over the end with a hose...
I just put a rubber plug over the end with a hose clamp. That way I still have access to it
Forum:
Pontiac - Race
04-26-2021, 05:33 PM
11
2,643
Posted By
firechicken
I removed the stick and just screwed an 1/8" pipe...
I removed the stick and just screwed an 1/8" pipe plug into the open end of the tube.
Forum:
Pontiac - Race
04-26-2021, 05:24 PM
11
2,643
Posted By
Scott Stoneburg
Mine was tapped to a pipe plug size and had a...
Mine was tapped to a pipe plug size and had a pipe plug in it.
Forum:
Pontiac - Race
04-15-2021, 04:21 PM
15
Round port headers
2,786
Posted By
Dragncar
My headers have standard grade 8, heads 9/16 on...
My headers have standard grade 8, heads 9/16 on some. And stainless 5/16 6 point on others. You need 6 point on some so you can get a opened end wrench on some. And the 9/16 head is much less likely...
Forum:
Pontiac - Race
04-15-2021, 03:28 PM
15
Round port headers
2,786
Posted By
Hooter
I've had good luck with Remflex gaskets.
Forum:
Pontiac - Race
04-15-2021, 12:38 PM
15
Round port headers
2,786
Posted By
Dave Polichena
Header bolts that have a 3/8 12 point hex works...
Header bolts that have a 3/8 12 point hex works great.
I like the Mr. Gasket Ultra Seal gasket.
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
01:59 PM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
