Old 05-04-2021, 08:13 PM
chaosrob chaosrob is offline
Default 1976 Dash/vin questions
My 76 has a 80-81 dash in it (has the two speaker holes left and right) and pulse wipers (that actually work). My question is does the vin have to be monkeyed with in order to change the metal part of the dash? It makes me a little nervous. TIA
Old 05-05-2021, 10:01 AM
Aus78Formula Aus78Formula is offline
It depends, but not really on both accounts. For most years it is simply a plate held up in place by a bracket which is riveted onto the lip of the dash metal, under where the dashpad meets up. On 80-81 or so, they started using that rosette style rivet and it passed all the way through the dash metal to be seen through the window. You will know which type you have by that feature, or if the speakers have been grafted into the earlier dash metal. Also, the later style changed VIN number styles so the cutout is much longer and wouldn't even fit your original VIN plate properly.
Mine has been apart from an earlier restoration and repaint, perhaps others could tell if the undersides were regular rivets or rosette style too on the earlier years.
Old 05-05-2021, 10:05 AM
This is what I have. Thank you very much for the replyClick image for larger version
Old 05-05-2021, 10:10 AM
Interesting. I only have a few saved photos of this style. I was trying to work out if they'd extended the opening cut to cover the rivet holes but it seems nicely pressed with lip still.
I checked, it was 1981 for new opening and rivets through the top, so yours must be a 1980 dash top.
1981 Turbo TA Pace car exposed dash VIN rivets original by Aus78Formula, on Flickr
Here's the underside of my 78 with dash removed, a view you'll rarely see or find in a search. The black bracket supports the VIN plate. These are the rivets I asked about earlier as to what style the originals use here, mine has been apart.
Firebird dash metal VIN plate rust repair by Aus78Formula, on Flickr
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 05-05-2021, 11:55 AM
Looking at the grill openings in mine it appears they may have modified the original to accept the grills. It doesn't exactly look factory done
Old 05-07-2021, 04:47 AM
Just us here, I guess.
Old 05-07-2021, 06:49 AM
I'm pretty sure that the question is answered honestly. After looking closer at it obviously home modified, the steel part was never out of the car in this one.
Old 05-09-2021, 04:15 AM
Yes, it appears so in those larger photos. Was hoping someone could comment on the rivets also, many, many on this forum.
Old 05-09-2021, 06:51 PM
I apologize and was just looking at it from my point of view when your question is an interesting one. Maybe someone else will chime in
Old 05-10-2021, 10:06 AM
unruhjonny's Avatar
You made me look again - I agree with you.
1970 Formula 400
Old 05-12-2021, 02:22 PM
jerry455 jerry455 is offline
This is my 76 Firebird.
Old 05-13-2021, 08:37 AM
TAKerry TAKerry is offline
Originally Posted by jerry455 View Post
Attachment 566469
My 77 and 79 are the same. I havent looked close at the earlier cars and was surprised when looking at this thread with the exposed rivets. I would have imagined they would have been riveted to a piece of metal then the metal dash went over top.
Old 05-14-2021, 04:42 AM
Was hoping someone could post a photo of their untouched, riveted VIN plate from below to show how they looked originally. Mine has been apart.
Old 05-14-2021, 02:59 PM
Stan65 Stan65 is offline
I don’t have a picture, but....
They were riveted using rosette rivets from the bottom. The order was rivet, support bracket, VIN plate, then dash.
The rosettes show from the bottom. From the top, With the dash pad removed it looks like the shank end of a normal rivet sticking up.
I added the stereo speaker grills to my dash. I also still have the center grill for my center channel.
My car is not quite original. Lol
ID:	566561   Click image for larger version
Old 05-16-2021, 12:02 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
Here is the rosette rivet from the underside of the dash on my '74
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 05-16-2021, 05:48 PM
Thanks Rick
