Old 02-09-2024, 08:39 PM
SD455DJ SD455DJ is offline
Originally Posted by 67Lemons View Post
As I mentioned above. There are a pair of #62 heads available locally but they have 72cc chambers which would probably be too much compression for the street with my stock pistons in the ‘68 short block?
My current 15’s are supposed to be 75-78cc’s from the factory, will the 72cc heads raise compression too high for pump gas with the stock original pistons in my 1968 400?
Your ’68 #15 heads are listed at 75 cc chambers (10.5 advertised compression) and the ’70 #16 heads are listed as having 78 cc chambers (10.0 advertised compression). My #16’s measured 80 cc’s before resurfacing and 78 cc’s afterwards, right on the advertised chamber size. My 400 is + .030” over, so actually 406 cu. in., with a quench of .040”. The actual calculated static compression is 9.94 to 1. With your std. bore block and factory pistons, probably .020” in-the-hole, your actual compression with your #15 heads would be close to 9.80 with a .039” head gasket (Felpro 1016). Quench would be ok at roughly .060". This would be manageable on 93 octane fuel with a factory style (slow) timing curve and carb jetting slightly on the rich side, along with a good cooling system (temps under 190).
Dennis
  #42
Old 02-10-2024, 12:12 PM
Lee's Avatar
Lee Lee is offline
Originally Posted by Jay S View Post
Keeping with 1.5s, with no jump in lift against a 068 is the Melling SPC-3 (744). It does not have the dwell over the nose of the old 744 cam, and doesn’t require extra spring pressure over a Melling SPC-7 (068).
Lee on here has the biggest cam I have seen successfully using press in studs, is in a 455. IRC…about .445” lift and 222*@.050 intake, just over .43” lift and 240* ish on the exhaust.
222/242 @ 0.050", .443/.435 valve lift, 116lsa. It has been on a 111icl, but I just changed that to 113 (and installed a converter with a bit more stall). I had the cam custom ground at Bullet.
I have the pressed-in studs, as well as the rest of the stock non-adjustable valvetrain parts. Somebody pointed out that my cam is somewhat similar to a 744, if 1.65's were used on the 744.
FAR from the fastest car I've ever owned, but it still has enough power to be fun to drive, and does it on 87 octane :-)
Dyno graph for when it was on the 111icl. I'll try to dyno again soon, to see what difference the 113icl made.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
The Following User Says Thank You to Lee For This Useful Post:
  #43
Old 02-10-2024, 03:29 PM
67Lemons 67Lemons is offline
That is a pretty cool build that you obviously put a lot of thought into. What was the reasoning for sticking with the stock valve train & press in studs? A specific class that you race or ?
  #44
Old 02-10-2024, 05:13 PM
Lee's Avatar
Lee Lee is offline
I was a bit curious about what sort of performance I could get with the non-adjustable valvetrain, and also with a low-compression 87 octane limit.
I've gone 11.2's with flat tappet cam and iron D-ports, 93 octane and streetable. Built a bunch of 9.0-9.5 Dport 455 type motors. I wanted to do something different this time.
It has done better than I expected :-)
  #45
Old 05-15-2024, 01:08 PM
68bobcat 68bobcat is offline
I cc'd my #62 heads recently. Unmolested November 1968 with new guides and seats. Large valves with screw in studs.
Volume range was 71.7cc to 72.9cc
The Following 2 Users Say Thank You to 68bobcat For This Useful Post:
