Old 09-01-2021, 11:29 AM
J.C.you's Avatar
J.C.you J.C.you is offline
Question 63 cat rear wheels/ tires?
Doing a tribute sd 63 cat and getting to the best rear steel wheel/ tire sizes combo without cutting wheel wells. (Maybe trim lip though). I would like to put a vintage white wall cheater slick tire on the rear......suggestions?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 09-01-2021, 12:01 PM
ben3843100 ben3843100 is offline
Even thought the title references “‘66 Bonneville”, I believe there is some info in the following thread related to what fits on the pre-‘65 cars.
biggest tire on 66 bonneville?
https://r.tapatalk.com/shareLink/top...ink_source=app
Old 09-15-2021, 11:43 AM
J.C.you's Avatar
ok, thanks...noted.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 09-16-2021, 12:58 AM
We ran M/T cheater slicks on stock steel wheels in the 1960's and 70's on our 1962 Catalina with no cutting. They were only 7 inches wide and had red and white side walls.
Old 09-16-2021, 05:24 PM
389 389 is offline
Wheel Vintiques has the stock steel wheels for the 5 x 5 bolt circle. There called Series 62 Summit sells them. Or you could make a set from some old wheels that are riveted. Buy new hoops and have them welded..
Old 09-16-2021, 07:15 PM
misterp266's Avatar
What do you consider “stock” steel wheels? Wheel Vintiques wheels do not allow the use of correct “stock” dog dish caps plus they will not clear calipers on a disk brake conversion.
" Darksiders Rule "
Old 09-17-2021, 12:11 AM
I didn't necessarily mean stock 1962 Pontiac. I mean we used a steel wheel off any car we could find that had the correct bolt pattern. In fact I used 1957 Mercury 15" wheels on my 1963 Pontiac for my snow tires. Later Pontiac 15" wheels will fit and most likely clear your disc brakes.
