Old 05-07-2017, 02:48 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default Four Link
Have any of you guys used this kit?
https://www.newegg.com/Product/Produ...87&ignorebbr=1
Old 05-08-2017, 09:16 PM
ahnuld's Avatar
ahnuld ahnuld is offline
wow i'd like to know if someone used this, i don't see instructions posted, you'd still need panhard bar and coilovers. looks cool though
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
Old 05-09-2017, 08:19 AM
62cat's Avatar
62cat 62cat is offline
Don't need a panhard bar with triangulated 4 link.
Old 05-09-2017, 10:27 AM
sdbob sdbob is offline
You'll need crossmember for attaching front. I've been watching trying to learn about triangulated rear 4link. The one was called Satchell link, after Terry Satchell. The 2 bottom bars are angled towards center line of car,angle 45 degrees,top bars are straight forward looking from top view. So cross member and bars need to be strong. Not sure how well this would work on street. I thought about ladder bar for simplistic application but they don't seem to handle well from what I've read.Still reading for my 63. I started a 4 link for it back in late 60s then it has been sitting.Other projects and work.
Old 05-09-2017, 07:17 PM
ahnuld's Avatar
I have ladder bar setup on mine and drive it almost everyday, no problems with several thousand miles and my car is usually loaded with kids or adults, and i don't drive it very nice at all.
Old 05-10-2017, 06:56 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
I used the triangulated 4 link setup on my 63 and have over 6500 miles on it and still love it. It's similar to the "A" car setup (64 & up) and doesn't require a panard bar since the triangulated set up negates any lateral movement. I think that I used the Art Morison kit. John
Old 05-21-2017, 09:32 PM
heater63's Avatar
heater63 heater63 is offline
I converted mine last year using a triangulated 4 link. Love it! No problems and never looked back
Got mine from Welder Series
http://www.welderseries.com/
QA1 coil overs
GM 10 bolt (72 Camaro stock width)
"If you aren't first, your last." Ricky Bobby 2006
Old 05-28-2017, 10:50 PM
hobbygto65's Avatar
Heater63, what did you use for coil overs?
Old 05-28-2017, 10:55 PM
tom s tom s is online now
My coil overs and ladder bars have been in for 20 years now.Tom
Old 05-29-2017, 04:46 PM
heater63's Avatar
That is the last thing I want to address. I am happy enough with my set up now I would just like to be able to adjust. Going to replace with with QA1 or Viking adjustable coil overs. Currently they are Morose adjustable drag shocks and QA1 14HT200 coils
This set up really grabs and goes
I just put a 400 with a 200R4 into my car this winter. Very happy with this set up.
Heath
Old 07-09-2017, 11:03 PM
hobbygto65's Avatar
Any one, please post photos of your rear suspension. 4 link link, triangulated or ladder bars. Trying to decide which way to go.
Old 07-10-2017, 12:07 AM
I used a triangulated setup (like an A car) doesn't require panard bar and really handles well. I think either parallel or triangulated will both work out fine! John
ID:	458445   Click image for larger version
ID:	458446   Click image for larger version
ID:	458447   Click image for larger version
ID:	458448   Click image for larger version
Old 11-23-2017, 12:42 AM
hobbygto65's Avatar
Update on my 4 link project, got the crosmember for the bottom arms fabbed tonight.
Old 11-23-2017, 02:47 PM
blueghoast's Avatar
Default 4-Links
Take a look at the olds and buicks of the same years.
They are tryangled to, might give you some ideas.
GT.
Old 11-27-2017, 10:57 AM
Anthony Anthony is offline
I'm Looking at getting a 62 Tempest and am wondering would this kit also fit a 62 or are they different?
Thank you,
Anthony
Old 11-27-2017, 07:31 PM
Sledder_duner Sledder_duner is offline
Here is my ladder bar set up.
ID:	468810   Click image for larger version
ID:	468811   Click image for larger version
ID:	468812   Click image for larger version
Old 11-27-2017, 08:13 PM
Shock cross member pic.
ID:	468814   Click image for larger version
Old 11-28-2017, 12:43 PM
blueghoast's Avatar
Thank you,
Anthony
Yes it's univercle. Might be some modifications you'll have to do for
mounting location other than that it's suppose to fit all.
GT.
Old 11-28-2017, 12:50 PM
just remember like SD did you need to reinforce when welding to the unibody,the metal is thin and can rip out.Happened on my panhard bar.Tom
Old 11-29-2017, 08:23 PM
hobbygto65's Avatar
Sled dunner, what rate springs did you use?
