Remember Me?
Join us now!
Menu
FAQ
Members List
Social Groups
Calendar
Search
Today's Posts
PY Albums
FAQ
Community
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Members List
Search Forums
Show Threads
Show Posts
Advanced Search
Find All Thanked Posts
Go to Page...
Search Forums
Search Results
Page 1 of 3
1
2
3
Showing results 1 to 25 of 54
Search took
0.02
seconds.
Search:
Posts Made By:
Don 79 TA
Forum:
Pontiac - Race
04-08-2024, 02:22 PM
18
Anyone install baffles in factory gas tank?
1,116
Posted By
PAUL K
Not many folks making those in 1990 These...
These young guys are spoiled lol
Forum:
Pontiac - Street
03-21-2024, 07:46 AM
56
Musi Pump gas 555
2,509
Posted By
HWYSTR455
I mentioned that 571 build above, curious, what's...
I mentioned that 571 build above, curious, what's the bore & stroke on that?
Forum:
Pontiac - Street
02-11-2024, 09:29 PM
81
Breaking in your new engine and Break In Oil
5,508
Posted By
Sirrotica
I've built dozens of engines over the last 5...
I've built dozens of engines over the last 5 decades. How in the heck did I ever get so lucky to never have trouble with them using plain old oil, and STP, or Lubriplate 110, calcium based grease, on...
Forum:
Pontiac - Street
02-11-2024, 06:16 PM
99
Wix 51258 Discontinued
5,940
Posted By
Formulajones
I've never liked the ac delco filters. Even way...
I've never liked the ac delco filters. Even way back in the 90's I felt they were poor quality when I was cutting them apart, typically finding a loose filter inside due to the retaining device...
Forum:
Pontiac - Street
02-07-2024, 10:44 PM
16
Going to build one more...
1,598
Posted By
65 Lamnas
It's been almost 15 years since my last Lamnas, and I'm not getting any younger, sooo....
Last year I found a rust-free '65 Lamnas near me for sale. PO had owned for maybe 5 years and had fun with...
Forum:
Pontiac - Street
01-31-2024, 07:46 AM
57
Flat Tappet Camshafts & More
3,694
Posted By
Cliff R
Some good points made. Very complex topic. ...
Very complex topic. Since I came up thru all of this and had 100 percent success with flat tappet camshafts for nearly half a century now I'm thinking I either dodged a...
Forum:
Pontiac - Street
01-28-2024, 10:20 PM
19
400 vs 455
1,251
Posted By
John Milner
Really, if 400 horsepower is the goal, a good...
Really, if 400 horsepower is the goal, a good running 400 with a set of 67-70 72cc big valve heads and something like a Crower 60916 or 60243 cam would likely get the job done.
Forum:
Pontiac - Race
11-25-2023, 02:09 PM
26
Increase Piston area for more TQ???
1,650
Posted By
Scarebird
If it worked the OEM's would be doing it.
Forum:
Pontiac - Street
10-31-2023, 05:42 AM
816
Question about 041 Cam
67,429
Posted By
Cliff R
Believe it or not I purchased all the parts for...
Believe it or not I purchased all the parts for my Distributor, a curve kit with weights and springs, the adjustable Vacuum canister and a special stop device that looks like a ruffle potato chip for...
Forum:
Pontiac - Street
10-29-2023, 02:01 PM
46
New HFT lifter from Comp Cams
4,078
Posted By
BILL BOWMAN1
Remember the 80’s when we slapped these motors...
Remember the 80’s when we slapped these motors together, fired them up, if the oil pressure was good and no leaks, we ran the snot out of them, without issue, and there wasn’t even the thought of...
Forum:
Pontiac - Street
10-23-2023, 08:14 PM
6
Fuel tank venting
736
Posted By
Tom Vaught
Without a vented (IN) gas tank, the gas tank...
Without a vented (IN) gas tank, the gas tank would collapse over time(atmospheric pressure.
The Ford Emissions guys in Allen Park Mi occasionally forgot to remove the cap when
draining (sucking)...
Forum:
Pontiac - Race
10-11-2023, 05:45 AM
8
1971 400 Block 2 to 4 bolt questions
912
Posted By
chuckies76ta
Like has been mentioned. Check out the after...
Like has been mentioned. Check out the after market blocks. Pick one and move on. Great investment in safety in my opinion.
Forum:
Pontiac - Street
09-27-2023, 09:31 AM
22
Vacuum pumps
868
Posted By
Tim Corcoran
My brother-in-law works for Lucas Oil as a...
My brother-in-law works for Lucas Oil as a chemist, one of his jobs is developing oil for the Childress race team which they sponsor. Anyhow he tells me that their oil stabilizer is what he calls...
Forum:
Pontiac - Street
09-18-2023, 09:56 PM
22
Vacuum pumps
868
Posted By
slowbird
Disagree. Every car benefits from vacuum pumps
Forum:
Pontiac - Race
09-15-2023, 04:10 PM
46
Water Leak from Head Stud
2,718
Posted By
PAUL K
It's common for the first design heads to crack...
It's common for the first design heads to crack and leak water there. It could also be leaking from the head bolt boss if there is a crack going into the water jacket. Sometimes when installing a...
Forum:
Pontiac - Race
08-24-2023, 04:25 AM
25
Excess crankcase pressure or oil control issue?
1,655
Posted By
chuckies76ta
Put a vacuum pump on it and be done with it. 8 to...
Put a vacuum pump on it and be done with it. 8 to 10 inches of vacuum at WOT will be enough. Seal up all the engine if you go with a vacuum pump. No breathers. Plug dipstick.
Forum:
Pontiac - Race
08-21-2023, 08:55 PM
23
Which oil weight
1,982
Posted By
Richie Hoffman
I have been using 20/50 in everything I build ...
I have been using 20/50 in everything I build it’s what has worked for me for 35 yrs.
Forum:
Pontiac - Street
08-14-2023, 09:11 PM
32
Stock 73 TA 455 rebuild.
1,545
Posted By
mgarblik
I will jump right in the deep end. You stated...
I will jump right in the deep end. You stated stock rebuild, stock look, sound and I assume performance. I see no need to replace anything with non-stock type parts to get the results you listed. ...
Forum:
Pontiac - Race
08-02-2023, 10:01 PM
6
Does anyone still make the timing cover that uses SBC water pump?
687
Posted By
Richie Hoffman
Jon Gunter Bayside Billet makes cover for sbc...
Jon Gunter Bayside Billet makes cover for sbc water pump
Forum:
Pontiac - Race
08-02-2023, 08:01 PM
6
687
Posted By
Joe-Touring
Looks like the benefits would be: SBC water...
SBC water pumps are much more common than Ponchos. And especially if you wanted to run an electric pump.
No more divider plate to clearance.
Last but not...
Forum:
Pontiac - Street
08-02-2023, 07:42 AM
17
Oil filter leak on 428
810
Posted By
JSchmitz
You could try some fluorescent oil dye and a UV...
You could try some fluorescent oil dye and a UV light. Something like this:...
Forum:
Pontiac - Street
07-31-2023, 07:37 AM
19
Butler- Used Heads and Cam-Worth buying?
1,212
Posted By
mpmsmuscle
You can take the BP numbers off those heads and...
You can take the BP numbers off those heads and call Jim Butler Performance and he can tell you what he did to these heads. And more than likely any port work or flow bench test numbers.
Forum:
Pontiac - Street
07-20-2023, 08:13 AM
42
Ordered new cnc heads today
3,364
Posted By
PAUL K
Both chamber designs have their place. Both...
Both chamber designs have their place. Both chamber designs are "good enough" to make over 1k HP NA. Best bet is to choose the chamber design that will work best for your application. However due to...
Forum:
Pontiac - Street
07-17-2023, 01:11 AM
15
Pre-front end alignment work
1,299
Posted By
73LeMans
Just a thought...ever think about using a mobile...
Just a thought...ever think about using a mobile flee/truck alignment guy? All my alignments are now done in MY garage without having to drive anywhere. Its more money yes, but a heck of a lot...
Forum:
Pontiac - Street
07-10-2023, 07:17 PM
8
Tkx trans adapter
618
Posted By
gtorich
Thanks 65madgoat for the info..............i got...
Thanks 65madgoat for the info..............i got the one from Fortesparts today..................maybe its just me, but i dont understand why this part isnt part of the trans no matter who you buy it...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
How to Subscribe to the Pontiac Journal
Pontiac Journal
PY Online Parts Lookup
General Forums
THE LOBBY
Industry Stuff
GTOG8TA.COM Late Model Stuff
Ames Customer Satisfaction Forum
Members Helping Members
Garage Sale
Pontiac Business Entities Exchange
Missing Pontiacs, Parts or Trailers
Test & Tune
YOUR BEST PONTIAC STORIES
Clubs, Events & Regional Discussion
National Events
Northeast
Southeast
Midwest
BuckeyeGoats.com
Pacific
West
Southwest
Canada, Mexico and Other Countries
General Classic PONTIAC TECH
The Body Shop TECH
Pontiac - Street
Pontiac - Race
Pontiac - Boost
LS Talk
Interior TECH
Heating & Cooling TECH
Suspension TECH
Exhaust TECH
Non Pontiac Motors in Pontiacs
Tri-Power Tech
Electrical Tech
EFI Tech
Classic TECH- specs, codes, resto issues FORUMS
60 & Older Pontiac TECH
61-63 Tempest & LeMans TECH
61-66 Big Pontiac TECH
64-65 GTO Tempest & LeMans TECH
OHC-6 TECH
66-67 GTO Tempest & LeMans TECH
67-79 Big Pontiac TECH
67-69 Firebird TECH
68-69 GTO Tempest & LeMans TECH
69-71 Judges only TECH
69-77 Grand Prix TECH
70-72 GTO Tempest & LeMans TECH
70-73 Firebird & TA TECH
71-77 Ventura including 74 GTO TECH
73-77 A-body TECH
74-76 Firebird & TA TECH
77-81 Firebird & Trans Am TECH
1982-92 TA & FB TECH
78 and Newer G-body Pontiac TECH
2004-06 GTO & 2008-09 G8 Tech & Chat
Other models Pontiac Tech
General Late Model Tech
PY Welcomes 1993-02 Firebird/Trans Am Owners
93-02 General Tech/Discussion
93-02 Interior Tech
93-02 Exterior Tech
93-02 Engine Tech
93-02 Transmission Tech
93-02 Exhaust Tech
93-02 Race Tech
93-02 Electrical Tech
93-02 Suspension Tech
93-02 Wheels/Tires
1993-02 Firebird/Trans Ams FOR SALE/WANTED
1993-02 Firebird/Trans Am Parts FOR SALE/WANTED
PY Welcomes 2004-06 GTO Owners
04-06 General Tech/Discussion
04-06 Interior Tech
04-06 Exterior Tech
04-06 Engine Tech
04-06 Transmission Tech
04-06 Exhaust Tech
04-06 Race Tech
04-06 Electrical Tech
04-06 Suspension Tech
04-06 Wheels/Tires
2004-06 GTOs FOR SALE/WANTED
2004-06 GTO Parts FOR SALE/WANTED
PY Welcomes 2008-09 G8 owners
G8 General Tech/Discussion
G8 Interior Tech
G8 Exterior Tech
G8 Engine Tech
G8 Transmission Tech
G8 Exhaust Tech
G8 Race Tech
G8 Electrical Tech
G8 Suspension Tech
G8 Wheels/Tires
2008-09 G8s FOR SALE/WANTED
2008-09 G8 Parts FOR SALE/WANTED
BUY, SELL, TRADE Classic PONTIAC "PARTS"
Performance Parts For Sale/Wanted
61-77 GTO, Tempest & LeMans Parts For SALE
61-77 GTO, Tempest & LeMans Parts WANTED
Big Pontiac (incl G-body)Parts For SALE
OHC 6 Buy/Sell/Trade
Big Pontiac(incl G-body)Parts WANTED
67-81 Firebird & TA Parts FOR SALE
67-81 Firebird & TA Parts WANTED
1982-1992 TA & FB parts FOR SALE
1982-1992 TA & FB parts WANTED
LS Parts for Sell/Trade
All other Pontiac parts for sale/wanted
Collectibles FOR SALE
Collectibles WANTED
SOLD Parts
BUY, SELL, TRADE Classic PONTIACS
Big Pontiacs(including G-body) FOR SALE
Big Pontiacs (incl. G-body) WANTED
61-77 GTO LeMans & Tempests FOR SALE
61-77 GTO LeMans & Tempests WANTED
67-92 Firebirds & Trans Ams FOR SALE
67-92 Firebirds & Trans Ams WANTED
All Other Pontiacs FOR SALE
All Other Pontiacs WANTED
SOLD Pontiacs
10:44 AM
-- Responsive 2017
-- PY Online 2015
-- Late Model - Blue
-- Default Style
---- PY Forums (green)
-- Test
-- 100% Default
Contact Us
Home
