Old 05-04-2024, 11:39 PM
Ramairnacho Ramairnacho is offline
Default 1970 pq transmission
Im.still gathering parts for my build and my transmission is original with about 112k miles on it. Car hasn't ran in 30 years. I basically want rebuilt drive train. I have read that I can have my torque converter Inspected and rebuilt and I'll do that. What rebuild kit is recommended for my transmission? I will not be drag racing car or any road racing just weekend cruising and lighting up tires every now and then. Basically stock build. I also like to know what correct transmission module is used on passanger side I believe. Can anyone tell me correct part number? I found this one but not sure if correct.
thanks
Old 05-05-2024, 10:38 AM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
thanks
All 65-72 TH400 service modulator kits took the same P/N 8625976. Not sure if the P/N was superceded in later years.
Are you doing the rebuild yourself or having it done?
If you're doing it yourself, there are a couple of websites where you can buy the parts fairly inexpensively. It's not a difficult task to do yourself, you'll just need a way to compress the piston springs.
The Following User Says Thank You to 65 Lamnas For This Useful Post:
