Old 04-23-2024, 10:40 PM
getmygoat's Avatar
Default Reassembled turbo 350 has noise in forward
Hi all,
I have a turbo 350 reseal project that went sideways on me. Long story short - when I removed the front pump to reseal it, I dislodged some of the clutches so had to get deeper into the trans than I would have preferrred.
Had a hard time getting it back together. Probably did it like 20 times, as I kept not having enough clearance to get the front pump back on. Thought I had finally got that sorted because on the "last" reassembly, when I turned the input shaft (trans vertical), I could not detect any movement of the intermediate clutch backing plate (indicating no contact between drum and plate).
Front pump went back on no problem - all seemed good.
Then I got the trans back in the car and hooked up the driveshaft. Upon turning the wheels in the forward direction, I get the noise shown in the video.
https://www.youtube.com/watch?v=1c7-rWECLUc
Sounds like a dumb question but any chance this is normal? If its wrong, I don't really know what I could have done wrong. Thanks for your expertise!
Old 04-24-2024, 07:59 AM
Half-Inch Stud's Avatar
Noise is a Sprag sounding normal.
