Old 04-22-2024, 03:03 PM
napster's Avatar
napster napster is offline
Default Need paint code for metal part of dash-1970 T/A
What is the paint code for the metal part of the cowl behind the dash pad on the inside of the front window? Light Blue for 1970 T/A.
Thanks in advance.
Old 04-22-2024, 05:39 PM
This may help:
Old 04-23-2024, 11:51 AM
napster's Avatar
John,
Thank you!
Jim
Old 04-23-2024, 08:33 PM
hiyabradHO hiyabradHO is offline
This may help:
John, Can you post the same for '71 please.
Old 04-23-2024, 08:56 PM
Old 04-23-2024, 09:15 PM
1971:
Thank you!!
Old 04-23-2024, 10:25 PM
Red80TA Red80TA is offline
Of course, you still have to come up with custom mixture based on that code if they recognise it at all. Being flat is the important part.
Old 04-24-2024, 10:03 AM
The original paint numbers were for a lacquer mix. The 0 degree gloss flat paint used on the metal dash structure had a suede additive which promoted a mild texture finish. Good luck trying to obtain/replicate in the lacquer paint mix w suede additive today.
This is an area I always look at early on when viewing freshly "restored" cars from local & regional shops that turn out multi make vehicles. Typ, the results viewed have been mediocre at best. With the substitution of modern paints, one will see everything from BC with a matte clear..uggh.. to the experimenting with misting of a dry coat on top of heavier coats.
Old 05-13-2024, 04:01 PM
MJZ's Avatar
MJZ MJZ is offline
Default Dash Black Paint Code 67
Does anyone know the interior paint code for black in a 67? Parchment interior with black dash. Thanks.
Old 05-13-2024, 06:13 PM
Try this:
Old 05-16-2024, 07:36 AM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
Default TCP global
TCP global will reproduce this exactly as it was with lacquer and the 0 gloss additive. Comes out as close as you can get. Looks good in my book to the original almost flocked look.
Get ready to pay. 1 quart is 295.00 bucks. I know just bought some a month ago for the 72.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
