Old 03-27-2024, 07:29 PM
1950Mercury 1950Mercury is offline
Default 66 Tri power center carb.
Looking for a center carb. for a 66 GTO tri power. Carb is 7026075. I need either a good carb a rebuilder or just the air horn. I have a complete carb but it leaks at the fitting. I changed the fitting and even double o ringed it and it still drips. I an thinking there may be a crack I can't see. I can get buy if someone has an air horn or tell me what other if any other horn will work.
Old 03-27-2024, 07:56 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
send your air horn to Mike at pontiactripower.com
Mike Wasson's #309-360-6385
He can fix yours
GtoFM's Avatar
GtoFM GtoFM is offline
Contact John or Mike at pontiactripower.com . They can fix that with a threaded insert or sell you an airhorn if he has one in stock.
Old 03-27-2024, 08:19 PM
Thank you. Is this kind of a common problem on these carbs? I've assembled many carbs. and this is a first for me.
Old 03-27-2024, 10:58 PM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
The float bowl and airhorn are cast pot metal. Threads strip from cycles and cross threading...pretty common for pot metal. Same problem on Q-jet inlet threads and needle/seat threads. If you've built many Quadrajets especially thru 1970 or so, you wouldn't be that surprised.
Old 03-28-2024, 12:56 AM
Yes I have seen many Quadra jets striped. I've actually used the kit to repair them. This 2 jet don't show any signs of trauma. That's what's confusing.
Old 03-29-2024, 11:00 PM
GtoFM's Avatar
The threads are not stripped but worn and stretched. pontiactripower.com charges $33 to repair, it's similar to a Helicoil. Go to the site and search 'thread' for the explanation.
Thread Tools
Display Modes
