Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 03-25-2024, 06:09 PM
GTO-relic GTO-relic is offline
Default RAM AIR V TUNNEL PORT COMP SOLID ROLLER CAM 279/284 dur, .673/.685 lift, 108LSA
COMP CAMS SOLID ROLLER
279/284 duration @ .050"
lift .673/.685 w/1.65 rockers
lift .612/.619 w/1.5 rockers
above figures with valve lash .028"/.030"
108 LSA, 102 ICL, 6 degrees advance ground in
will fit original Ram Air V tunnel port heads, McCarthy aluminum RA V heads, DCI Johnston RA V heads, Kaufman billet RA V heads
run for 30 minutes to set timing, carb
then replaced with smaller 250/270 duration solid flat tappet cam,
back in 1990.
this cam is not even fully broken in. like new.
in Comp box with cam card
$1200 cash pick up in person
will ship anywhere, with gifted paypal, postal money order
ID:	631029   Click image for larger version
ID:	631030   Click image for larger version
ID:	631031   Click image for larger version
ID:	631032   Click image for larger version
Old 03-28-2024, 10:53 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Is the buyer going to need to run a RAV distributor like an original RAV had or is this core set up for the Standard Pontiac distributor gear?
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
