Old 02-24-2024, 08:04 PM
phil400's Avatar
phil400 phil400 is offline
Default Fan Clutches
Thinking of swapping the original factory flex fan on my 78 to good heavy duty clutch fan, whats the consensus, thermal or non thermal? Any one having done this swapping have part numbers they used thanks?
78 T/A 4SPEED, Original paint, match #’s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs,mine since ‘99.
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
Old 02-24-2024, 08:29 PM
grivera's Avatar
grivera grivera is online now
Hayden 2747 - I never had a flex fan but the part number listed is the GOAT
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 02-25-2024, 08:51 AM
steve25 steve25 is offline
Be sure that if you should need to space the new set up that the fan blades are half way in and half way out of the shroud, or as close to that as you can get.
This is how they move the most air and the most common mistake that leads to temperature issues.
Set up’s with a clutch are heavier then just the flex fan set up, so if your water pump bearing and seal is on the way south you will find out about that sooner.
BTDT!
Old 02-25-2024, 08:59 AM
phil400's Avatar
Ok Thanks
77 t/a sold
83 Mustang GT sold
