Old 02-18-2024, 08:54 PM
1950Mercury 1950Mercury is offline
Default 1966 GTO wire help needed
Needing a little more guidance on this M&H under dash harness for 66 GTO w/ralley gauges 4 speed non air car. There is a brown 2 wires to a red plug about center of dash. On left side there is a fuse in a holder. I have no clue what for. More toward the right side there is a white wire with a plug and a gray wire with a plug. Again I have no clue. Then on the right side of the red plug with the 2 brown wires there is a tan colored wire with a plug. That one may be the same as the one toward the left with the black plug on it but unsure. I also see no wire for the e brake light in the speedo. area. I was thinking it might have something to do with the tach. I also have a tach harness also. Just one wire with a fuse. I have a wire diagram but it don't show this info. Hoping someone here may have used a M&H harness in the past and recall this.
ID:	628879   Click image for larger version
ID:	628880   Click image for larger version
ID:	628881   Click image for larger version
The Following User Says Thank You to 1950Mercury For This Useful Post:
Old 02-20-2024, 12:24 PM
gtospieg gtospieg is offline
Try to contact Pete Serio on this forum. He knows the wiring inside and out. He answered similar questions for me several years ago. He had the answers off the top of his head.
Old 02-20-2024, 01:06 PM
Kenth's Avatar
Kenth Kenth is offline
Why not ask M&H?
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-20-2024, 02:35 PM
I have yesterday. Spoke with Darin. There are so many issues with this car. Just trying to sort things out. I see crap that makes me shake my head.
Old 03-04-2024, 03:29 PM
On this M&H under dash harness there is a short wire near the fuse block with a fuse holder. Anyone know what that wire is for? This is a 4 speed non A/C car with the rally gauges. I notice the harness gas some extra wires such as volumn shift and a few other wires.
Old 03-05-2024, 06:29 AM
Jeff Hamlin's Avatar
Accessory lead. I just tucked it up as I didn't need it.
