Old 01-27-2024, 05:14 PM
PontiacLars PontiacLars is offline
Default Oil support rail gap
Ross pistons. 4.5" stroker, so pistons have oil ring support rails.
Ross instruction says gap should be minimum 0.010 and Max 0.187. I get 0.384. Is this a problem? Do I have the wrong support rings?
Old 01-27-2024, 06:01 PM
steve25 steve25 is online now
Who supplied the support rails, Ross?
Old 01-27-2024, 06:05 PM
Yes. Everything came with rotating assembly from Butler. The instruction sheet from Ross says rails are for a certain bore range and they should fit my 4.160 bore. But I dont like that they get way bigger gap than What is recommended Max in the same installation sheet.
