Old 01-25-2024, 01:01 PM
Gary H's Avatar
Gary H Gary H is offline
Default 65' GTO or Lemans Radio support brace
I need the support brace that goes between the radio and the bottom of the dash on a 65' GTO. Not sure if other years will work or not.
Old 01-25-2024, 02:29 PM
chrisp chrisp is offline
Easy to make if not wanting to wait for original .
Old 01-25-2024, 05:19 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Gary,
Maybe you already know this but the length/height, plus the bends of this radio support bracket is different between 1965 and 66-67.
I’m not sure of the 64 style.
Hope this helps.
ID:	627195   Click image for larger version
ID:	627196   Click image for larger version
ID:	627197   Click image for larger version
Old 01-26-2024, 09:20 AM
Gary H's Avatar
Originally Posted by 60sstuff View Post
Gary,
Hope this helps.
Thanks for this information. No, I wasn't aware of the differences. Still looking for one!
Old 01-26-2024, 11:46 AM
Old Goat Racer's Avatar
Is the bracket the same for a '65 AM and a AM-FM radio?
Everybody knows somthin.
Nobody knows everything !
Old 01-26-2024, 02:23 PM
BOB VIDAN BOB VIDAN is offline
I have the right bracket. PM with contact and ship to info. Also all the 66/67 brackets I've seen have a part number stamped in them, none of the 64/65 do. AM and AM FM brackets are the same.
Practicing social distancing for 65+ years
Old 01-26-2024, 03:18 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
No. The 65 AM/FM has a slightly longer chassis than the AM only and uses a different bracket.
1969 MPC 64-65 T/6, T/8 9773388 65 T/6,T/8 9781333 (AM-FM)
The 74 MPC no longer lists the 65 AM/FM bracket.
In fact I’m looking for a 65 AM/FM bracket but will most likely bend the AM bracket to fit or fab one up.
Old 01-26-2024, 06:49 PM
Gary H's Avatar
PM sent
Old 01-26-2024, 09:51 PM
Stand corrected on 65 usage, 64 - 3 Deuces is correct.
Old 01-28-2024, 12:49 PM
66/67 AM FM brackets are also different, AM vs AM/FM
