Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-18-2024, 06:59 PM
Tom63LeMans's Avatar
Tom63LeMans Tom63LeMans is offline
Default Offenhauser 2x4 Quadrajet Intake Manifold
This is rare 2x4 Offenhauser hi-rise intake cast for Quadrajet carburetors. The casting number on the bottom is 5499 and date 11-2-8. It does not appear to have been ported. There is a hole drilled on top of the right side near the water crossover probably for the PCV hose. The top plates are open center. I bought a set of Transdapt 1” closed center plates that could be drilled and countersunk for closed center plates if desired.
$600 OBO for the manifold.
$100 for the Transdapt spacers , they are $89 each new
Located in NE Ohio
ID:	626761   Click image for larger version
ID:	626762   Click image for larger version
ID:	626763   Click image for larger version
ID:	626764   Click image for larger version
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
