Old 01-11-2024, 09:49 AM
chuckies76ta's Avatar
Default TH400 Reid Case
Wondering if anyone has a TH400 Reid Transmission case sitting on there bench or can Identify these two ports for me. Thanks.
Name:	reid case4a.jpg
Old 01-11-2024, 04:36 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
My friend at JW says the rear port is for the rear servo, nothing for you on the front as theirs and Reid case does not have that port. Must be a new design
Dave Polichena
The Following User Says Thank You to Dave Polichena For This Useful Post:
Old 01-12-2024, 05:23 AM
Ok Thank you. So the other port has to be the front servo as both ports are on the same side. Next time I have it apart I will defiantly make some notes.
