Anybody recognize this HR camshaft
I googled the cam lobes and didn't have any luck, does anybody recognize these markings?
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
It is a compcams HUC high lift (.4”) marine profile.
13066 318 263 183 0.400
13068 326 271 190 0.400 114 LSA The HUC Series Hydraulic Rollers are very smooth designs intended for high RPM use with heavy valves. These are very similar to the Xtreme Marine high lift lobe series, but may be slightly more stable. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-17-2023 at 05:14 PM. |
Thank you Gentlemen, I appreciate it!!
Wow, one has too wonder what that sucker in! Take some big cubes (500 +) big heads and a ton of compression to make that work, then to run good it still probably needs a 200 shot of NOS. LOL
The cam the 461 in my TA is ground close to that, except 18* smaller than that one, also a marine type grind on a 114LSA and has .632” lift. My engine tq peak is right around 5000! The power band goes to 7000. That one makes my cam look small. |
What would you use that cam in ? One example....
I'm not at Liberty to provide exact details but I can say that years ago Ken Keefer (aka Pontiac Dude) used a similar hydraulic roller cam in his 535 cubic inch pump gas combination. He used a Comp Xtreme Marine High Lift lobe with similar .050" duration on the intake. Edelbrock cylinder heads, basic clean up. If memory serves me right about 300 cfm. Pontiacs in the Park. VMP 2008. Heads up Streetcar Shootout. 73 pills in a Big Shot plate. Stock suspension 3450 lbs. Hydraulic Roller AND Pump gas. 9.30@144 http://www.youtube.com/watch?v=BMFWOYr6VSE .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-19-2023 at 05:51 AM. |
HA! I was pretty close on the application!
Steve I’d say your memory is in good shape if you can pull that combination out from memory |
That cam was in a engine mark g ran on the street with solid roller lifters on it. Believe he got in the high 8s with it on spray.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
I've got the same cam and it works good in a 400 and 455.
It's in the motor in my 57-wagon now. GT |
I think you accidentally posted in the wrong thread?
