Old 12-11-2023, 05:25 AM
Ramairnacho Ramairnacho is offline
Default 1970 hood
Anyone got grills vents for this hood that can be graphed in? Or is that not possible. Corners are in Need of repair too. It doesn't have bracing bit needs tlc.i noticedits lighter that the steel reinforced ones. Is the actual frame structure the same or different? Never show a stranger your car because they might want to steel it or parts off it.Trust me I'm a victim of that.
ID:	624801   Click image for larger version
ID:	624802   Click image for larger version
Old 12-11-2023, 07:38 PM
unruhjonny's Avatar
based on the damage and holes drilled into the underside of the forward edge, I'd suggest you find another hood.
Those vent areas are VERY hard to repair, where the repair doesn't crack, or pop off;
I believe the best fix is to simply cut out the entire area, and replace with the same section of an undamaged hood.
These hoods are out there.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 12-12-2023, 01:51 AM
Those holes aren't stock? Wonder why? It does have hood pins. Well I wish I caught the their that stole my hood!
Old 12-12-2023, 11:22 PM
Default 1970 hood
I think the holes are stock. If I find a hood that's damaged with good vents I think this hood could be saved with a donor. If results not good then I'll hang it in garage.
Old 12-13-2023, 04:44 PM
unruhjonny's Avatar
ok, maybe I was wrong.
my knee jerk reaction was that this hood was going to require a lot of work - I have not known any vent damage to be able to be properly repaired to the point where it wouldn't crack down the road, and re-expose the original damage/repair;
Add to that, the picture made the holes look sloppy - so I probably mis-spoke.
1970 Formula 400
Old 12-13-2023, 09:58 PM
My '70 Formula's original hood has one hole per side. On your car, the one that is cleanly cut is original. The two that look hacked in.... are not.
Name:	Form Holes.jpg
Old 12-13-2023, 10:14 PM
Default 1970 holes
This is a pic of a low mile survivor. 3 per side. I believe holes are stock. I'll try to save the hood if it looks ugly I ll use a different one.
Old 12-15-2023, 09:05 AM
SD455DJ SD455DJ is offline
Same here, my original Formula RA Hood only has one hole per side and the inner most one.
Dennis
ID:	624998   Click image for larger version
ID:	624999   Click image for larger version
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
Old 12-15-2023, 09:23 AM
Here's another '70 LB RAIII Formula from the 2021 TA Nats with just a single hole per side.
Dennis
Old 12-19-2023, 07:30 AM
HWYSTR455's Avatar
As a reminder, Anvil now makes a carbon fiber/fiberglass Formula hood for $1500:
https://anvilauto.com/products/1970-...37624280055975
