Tri-Power Tech 57-66 Tri-Power Talk
Old 11-11-2023, 04:06 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default Original fuel line?
What was the original fuel line from fuel pump to carbs /filter on the 1965 tri-power?
Old 11-11-2023, 04:19 PM
Rubber.
Not all of the photos show up but Scott Tieman details the rubber line from the fuel pump to the filter in the Fuel pump section.
https://www.motortrend.com/how-to/de...er-389-part-2/
Old 11-12-2023, 09:45 AM
dhcarguy's Avatar
Thanks Greg
Old 11-12-2023, 10:38 AM
Stuart's Avatar
Stuart Stuart is offline
Rubber.
To be clear, the pictures there show there is a hard line from the front carburetor that goes down the front of the engine and disappears behind the alternator. I don't know the specifics about what was done in 1965 but on my car there's a rubber line from the fuel pump to the filter, then another short section of rubber line that connects the filter to the hard line that goes on up to the carburetors. I assume 1965 was similar.
Old 11-12-2023, 10:48 AM
bill ryder's Avatar
bill ryder bill ryder is offline
X2 definitely.
"Bill"!
Old 11-12-2023, 10:50 AM
Old 11-12-2023, 10:26 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
This is the 1965 Tri-Power fuel line on a GTO.
Rubber hose from fuel pump to fuel filter inlet.
Short piece of rubber hose from fuel filter outlet to aluminum fuel line.
Factory illustration shows a 1964 unit.
ID:	623229   Click image for larger version
ID:	623230   Click image for larger version
ID:	623231   Click image for larger version
ID:	623232   Click image for larger version
The Following User Says Thank You to 60sstuff For This Useful Post:
