Old 06-27-2023, 05:22 PM
Vid's Avatar
Vid Vid is offline
Default Forward lamp wiring harness replacement
Very excited to be replacing my original forward lamp wiring harness, it should clear up a myriad of mystery issues that I’ve been dealing with. Been cleaning up and replacing ground wires throughout the chassis too.
95% of this job is super simple. However I’m sure there is a trick to removing the forward lamp harness boss from the firewall (behind the brake booster). Anybody here dealt with removing the block from the firewall lately? I found one article that says just pull it straight out from the firewall. Is that correct or is there a fastener holding it tight? I’m guessing there must be a screw or two hiding in the tar or whatever that gunk stuff is. It’s the block on the right in the photo. Thanks.
Old 06-27-2023, 10:56 PM
Vid's Avatar
Vid Vid is offline
Figured it out. All I needed was a brighter light, lol
Old 06-27-2023, 11:06 PM
Sometimes the best way to figure something out…..is to make a post on an Internet forum…..then and only then you’ll find that it wasn’t really all that hard to figure out after you looked at it again…..
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 06-28-2023, 11:38 AM
Vid's Avatar
Vid Vid is offline
Yeah exactly, especially here in everybody’s favorite department… electrical.
The Following User Says Thank You to Vid For This Useful Post:
